大家好,
在PoSoC4200模拟协处理器CY8C4A45 PVI-48 1中,我不能用DIEOTEMP测量CIP的温度。 转换器返回值440 @ 27°C,但“TEMP= dieEntHy11CurtStoxCelsiUS(ADCTEMP)”; 你有什么专门的例子吗? 谢谢你 以上来自于百度翻译 以下为原文 Hello to all, I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481'. The converter returns the value 440 @ 27 ° C, but "Temp = DieTemp_1_CountsTo_Celsius (adcTemp);" does not return the value in Celsius. Do you have any dedicated examples? Thank you |
大家好,
我不能用Psoc Creator 4.1的PSOC4200模拟协处理器CY8C4A45 PVI-48 1用DIEOTEMP测量CIP的温度。 转换器返回值440 @ 27°C,但“TEMP= dieEntHy11CurtStoxCelsiUS(ADCTEMP)”; 你有什么专门的例子吗? 谢谢你 以上来自于百度翻译 以下为原文 Hello to all, I can not measure the temperature of the cip with the DIE_TEMP in PSoC4200 Analog Coprocessor CY8C4A45PVI-481' whit Psoc Creator 4.1 The converter returns the value 440 @ 27 ° C, but "Temp = DieTemp_1_CountsTo_Celsius (adcTemp);" does not return the value in Celsius. Do you have any dedicated examples? Thank you |
60user3 发表于 2018-9-12 11:47 示例固件源Code PSoC Creator提供了许多示例项目,其中包括在查找示例项目对话框中的示意图和示例代码。对于组件特定的示例,从组件目录中打开对话框或在示意图中打开组件实例。对于一般示例,从开始页或文件菜单打开对话框。根据需要,使用对话框中的筛选选项来缩小可供选择的项目的列表。有关更多信息,请参阅PSoC Creator帮助中的“查找示例项目”主题。 HTTP://www. CyPress .COM/FIL/139101下载 试着在PSoC Creator中建立一个温度的例子,让我们知道这对你来说是如何的。 以上来自于百度翻译 以下为原文 Sample Firmware Source Code PSoC Creator provides numerous example projects that include schematics and example code in the Find Example Project dialog. For component-specific examples, open the dialog from the Component Catalog or an instance of the component in a schematic. For general examples, open the dialog from the Start Page or File menu. As needed, use the Filter Options in the dialog to narrow the list of projects available to select. Refer to the "Find Example Project" topic in the PSoC Creator Help for more information.http://www.cypress.com/file/139101/download Try building one of the examples in the PSoC Creator for temperature and let us know how that goes for you. |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
512浏览 2评论
471浏览 2评论
423浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-5 09:43 , Processed in 0.677387 second(s), Total 45, Slave 40 queries .
