如何在H3LIS331DL加速度计上配置数据就绪中断?我已经配置了像LIS3DSH这样的其他加速度计,但我仍然坚持这一点。
我已经尝试了锁存和脉冲中断,我已经将INT1和INT2上的信号配置到配置寄存器上的Data Ready,但它似乎没有做任何事情。我很感激任何指导,如果需要我可以发布代码。 提前致谢!! #h3lis331dl数据就绪中断 以上来自于谷歌翻译 以下为原文 How does one configure the data ready interrupt on the H3LIS331DL accelerometer? I've configured other accelerometers like LIS3DSH with success but I am stuck on this one. I've tried both latched and pulsed interrupts, I've configured the signal on both INT1 and INT2 to the Data Ready on the configuration register but it doesn't seem to do anything. I would appreciate any guidance, I can post the code if needed. Thanks in advance!! #h3lis331dl-data-ready-interrupt |
3个回答
你好,
您能否分享您的寄存器设置? 此外,只有一个项目问题发生了吗?您是否可以使用其他H3LIS331DL IC进行测试? 谢谢! 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello, Would you please be able to share your registers setup? Also, did the problem happen with only one item? Were you able to test with other H3LIS331DL IC? Thank you! Thiago Reis |
我刚才解决了这个问题。配置很好,数据就绪中断发生但我没有读取输出寄存器,导致不再发生数据就绪中断。当我注意到这一点时,我轻松解决了这个问题。
以上来自于谷歌翻译 以下为原文 I solved the problem a while ago. Configurations were fine, Data Ready Interrupt ocurred but I didn't read the output registers, causing that no more Data Ready Interrupts would occur. When I took notice of this I easily solved the problem. |
嗨Wa ,,
我知道它有点迟了但我有同样的问题。你可以发布你的代码设置吗?我知道你可能不会再读它了,但值得一试。 最好, Goekhan 以上来自于谷歌翻译 以下为原文 Hi Wapers, I know it is a little bit late but I have kind of the same problem. Could you post the setup of your code? I know you might not read it anymore but it is worth a try. Best, Goekhan |
2985 浏览 1 评论
3313 浏览 1 评论
1894 浏览 1 评论
3747 浏览 6 评论
6163 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
55浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
60浏览 5评论
92浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
60浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
56浏览 5评论
GMT+8, 2025-4-6 08:30 , Processed in 0.826326 second(s), Total 81, Slave 65 queries .
