嗨,我在Windows 8.1上使用ADS 2014。
我定义参数化布局并为其创建EM模型和符号。 我想在原理图上优化其参数。 当我将其符号放在原理图上并更改其参数并运行模拟时,EM模拟运行但结果与我在单元格参数中定义的默认值的结果相同。 我不知道我的窗户是否有问题,或者我在ADS中犯了错误。 谢谢 以上来自于谷歌翻译 以下为原文 Hi, I use ADS 2014 on windows 8.1 . I define a parametric layout and create EM model and symbol for it. I want to optimize its parameters on a schematic. When I place its symbol on a schematic and change its parameters and run the simulation, EM simulation runs but the results are same as the results with the defaults values I have defined in cell parameters. I don't know whether there is a problem with my windows or I make a mistake in ADS. Thanks |
不确定这是错误还是功能,但默认情况下,布局使用“固定”表示并忽略单元格参数。
您需要更改一个设置以确保单元格的实例根据单元格参数进行绘制:使用参数化布局打开单元格。 转到文件>设计参数在出现的对话框窗口中,转到“特定于视图的配置”选项卡,然后将下拉列表从图稿类型“使用此布局”更改为“参数化”。 以上来自于谷歌翻译 以下为原文 Not sure if this is bug or feature, but by default, the layout uses a "fixed" representation and ignores cell parameters. You need to change one setting to make sure that instances of your cell draw according to the cell parameters: Open the cell with the parameterized layout. Go to File > Design Parameters In the dialog window that comes up, go to the "View-Specific Configuration" tab and change the drop-down list from artwork type "Use this layout" to "Parameterized". |
1366 浏览 0 评论
2412 浏览 1 评论
2253 浏览 1 评论
2098 浏览 5 评论
2995 浏览 3 评论
1362浏览 1评论
810浏览 0评论
1138浏览 0评论
1367浏览 0评论
GMT+8, 2025-2-13 01:00 , Processed in 1.906041 second(s), Total 77, Slave 61 queries .
