扫一扫,分享给好友
我为Wi10进行了CysB3的驱动程序转售过程,它看起来是安装和工作的。很好,谢谢。然而,修改后的驱动程序包,我提交只包括我们公司的USB设备(VID/PID)。我也想添加一个默认的CyPress VID/PID到我们的INF,这样我们就可以很容易地编程新的/空白的董事会,我们收到。从CysB.PDF看来这似乎很好?在微软HW仪表板上提交另一个修改包之前,我想检查一下。
具体问题: 1。第三方允许将CyPress VID/PID添加到他们的驱动程序包中转售吗? 2。如果我可以添加CyPress VID/PID(或者如果我需要添加我们自己的新VID/PID),我需要把这个新的INF提交到CyPress吗?或者我可以把另一个修改的驱动程序包上传到仪表板上(与最初的一样)吗? 2、如果我需要先提交一份INF给赛普拉斯,那么如果威廉希尔官方网站 案例消失了,我该怎么办呢? 谢谢, 埃里克 以上来自于百度翻译 以下为原文 I went through the driver resell process for cyu***3 for win10, and it appears to be installing and working. Excellent, thank you. However, the modified driver package that I submitted only included our company's USB devices (VID/PIDs). I would like to also add a default Cypress VID/PID to our INF so that we can easily program new/blank boards we receive. From the CyUSB.pdf this seems perfectly fine ? I wanted to check before submitting another modified package on the microsoft hw dashboard. Specific questions: 1. Are third parties allowed to add Cypress VID/PIDs to their driver package for resell ? 2. If I can add Cypress VID/PIDs (or if I need to add our own new VID/PID), do I need to submit this new INF to cypress or can I just upload another modified driver package to the dashboard (same as initial one)? 2.a. If I need to submit an INF to cypress first, how would I go about doing that now that technical cases are gone ? Thanks, Erik |
你好,埃里克,
第三方供应商通常不允许在CysB3.IF文件中添加CyPress VID/PID。问题是当你推动驱动程序进行Windows更新时,CyPress VID/PID也会被推到WU。当其他客户使用同一个CyPress VID/PID时,这会导致问题,并且驱动程序使用不同的名称字符串。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Erik, - Third party vendors are generally not allowed to add Cypress VID/PID in the CyUSB3.INF file. The problem is that when you push the driver for Windows Update, the Cypress VID/PID also gets pushed to the WU. This can cause problems when other customers use the same Cypress VID/PID and the driver comes up with a different name string. Best regards, Srinath S |
wangcong12138 发表于 2018-9-10 20:16 谢谢,这很有道理。我认为内部可能会启用机器上的测试签名,并使用未签名的驱动程序进行初始编程。 以上来自于百度翻译 以下为原文 Thanks that makes sense. I think internally we'll probably enable test-signing on the machine(s) and use an unsigned driver for initial programming. |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3421 浏览 0 评论
2301 浏览 1 评论
2020 浏览 1 评论
3864 浏览 1 评论
1921 浏览 6 评论
4077浏览 2评论
2598浏览 2评论
583浏览 2评论
560浏览 2评论
4354浏览 2评论
GMT+8, 2025-7-12 23:46 , Processed in 1.065038 second(s), Total 49, Slave 43 queries .
