我只想要一个指向规格和内容的链接,如果它在vmware fussion中工作得很好我可能以后得到工作站但不想要虚拟机,我不想要用java编程的东西。
我不想要一些必须拨打回家的东西,我不能把我的带宽占用,当我可以访问互联网时,我们经常辍学,所以我希望有一些可以离线运行的东西,因为我们倾向于 通常没有互联网接入,在我花费大量资金之前,我想确保它不仅在速度方面真的很快,而且我还活在不太好的网络区域,没有良好的互联网速度和辍学 是一种频繁和长期的出现。 如果它适用于其他Vm和哪一个。 如果还没有消费者型号,请在需要时通知我。 谢谢 以上来自于谷歌翻译 以下为原文 I just want a link to the specs and stuff and if it works good in vmware fussion I may later get workstation but do not want virtualbox, I do not want something programmed in java. I do not want something that has to dial home, I can't have my bandwidth taken up by somethinglike that when I can access the internet, we have frequent dropouts so I would like to have something that can be run offline as we tend to be often without internet access and before I spend a large amount of money I want to make sure that it is truely fast not only in speed but I also live out in a not so great rual area that dosen't have good internet speed and dropouts are a frequent and lenghthy occurrance. Also if it works in other Vm's and which one's. If a consumer model is not yet available please let me know when one is. Thank you |
嗨,
我真的不知道你的要求是什么。 确保GPU是企业解决方案,而不是消费者。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, I have really no clue what your request is about. For sure vGPU is an Enteprise solution and not for consumers. Regards Simon |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3145 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3561 浏览 4 评论
GMT+8, 2025-1-9 00:51 , Processed in 0.546810 second(s), Total 73, Slave 57 queries .
