迈克,谢谢你的回答...这真的是我想要的。保罗,保罗-----原始信息-----来自:M Watts To:Paul Cc:VEE Reflector(E-mail)发送:星期三,
2002年7月17日4:26 AMSubject:vrf从格式化的文件保护中获取字段,您只需要使用“读取令牌”功能 - 对于此类问题,它是一个非常强大的解决方案。 请参阅随附的示例.Regards,Mike Watts_______________________________________________________________________ Michael Watts,顾问PO Box 92网站:www.PreciselySo.Co.UK埃克塞特,德文电子邮件:MJWC@PreciselySo.Co.UK英格兰电话:+44 7714 339 729 EX4 2YY _______________________________________________________________________------------------------------------------------- --------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Mike, Thanks for your answer... it really what I want. Regards, Paul ----- Original Message ----- From: M Watts To: Paul Cc: VEE Reflector (E-mail) Sent: Wednesday, July 17, 2002 4:26 AM Subject: vrf Get field from formatted file Paul, You just need to use the 'read token' feature - it's a very elegant solution for this type of problem. See the attached example. Regards, Mike Watts _______________________________________________________________________ Michael Watts, Consultant PO Box 92 on the web: www.PreciselySo.Co.UK Exeter,Devon e-mail: MJWC@PreciselySo.Co.UK England tel: +44 7714 339 729 EX4 2YY _______________________________________________________________________ --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
3个回答
I made a burn in program which controlled 6 serial ports in sequence. I made
one com port box and added a device name (if memory serves correctly) input pin and cycled through the port names using a for range box and a formula box to drive the serial port object. I don't think VEE has any limit on the number of ports. Mark -----Original Message----- From: Tim Xing [mailto:TIMX@labconco.com] Sent: Wednesday, July 17, 2002 7:05 AM To: vrf Subject: vrf talk to 10 serial ports Hi, Does anyone know how to connect more than 4 serial ports in VEE. I have 10 ports (com1 to com10) but VEE only supports 4. Thank you. Tim Xing Dept. of Engineering Labconco 8811 Prospect Ave. Kansas City, MO. 64132 (816) 822-3759 --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
1510 浏览 0 评论
2492 浏览 1 评论
2339 浏览 1 评论
2189 浏览 5 评论
3122 浏览 3 评论
1710浏览 1评论
918浏览 0评论
1510浏览 0评论
GMT+8, 2025-4-22 23:10 , Processed in 1.480761 second(s), Total 80, Slave 64 queries .
