对于接收器重新协商电压,我想使用这些步骤
用DPMIUPDATEY SNKYMax MyPMPODPDY命令(0,DPMY-CMDYGETHYSRCCAP CAP,NULL,PDY命令DB)命令更改宿功能运行时;DPMYPPDY命令(0,DPMY-CMDY-SKKYCAPCHNCHG,NULL,PDY命令DB); 这个程序的功能dpm_update_snk_max_min要求“max_min”数组作为参数但在SDK这个数组的结构是不明确的。这是任何规定和/或有例子代码可用吗? 以上来自于百度翻译 以下为原文 For a sink to renegotiate the voltage I want to use these steps
For this procedure the function dpm_update_snk_max_min requires a "max_min" array as parameter but in the SDK the structure of this array is not specified. Is this anywhere specified and/or is there example code available for this? |
3个回答
***4 发表于 2018-9-6 09:42 所以这只最大电流可以改变吗?SDK描述是 “指针最大/最小电流/功率阵列” 是否也可以动态地适应汇电压,哪个函数必须用于此? 另一个问题是,如果有一个函数返回的实际电压和电流由CGG3监测? 以上来自于百度翻译 以下为原文 So this only the maximum current can be changed? As the SDK description is "Pointer to max/min cur/power array'" Is it also possible to adapt the sink voltage dynamically, which function must be used for this? Another question I have is if there is a function which returns the actual voltage and current as monitored by the CCG3? |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1599 浏览 1 评论
944浏览 2评论
660浏览 2评论
511浏览 2评论
478浏览 2评论
1346浏览 2评论
GMT+8, 2025-4-4 20:07 , Processed in 1.018338 second(s), Total 51, Slave 44 queries .
