我试图为Horizon构建一个Windows 10虚拟机,我无法安装vvU使用的nvidia网格驱动程序。
我有一个工作的Windows 7虚拟机,它使用k120q配置文件为我们的K1卡配置了共享PCI设备,所以我知道该卡正在工作。 我将共享PCI设备添加到Windows 10并尝试安装驱动程序(361.75),它告诉我“这个图形驱动程序找不到兼容的图形硬件。” 设备管理器显示Microsoft Basic Display Adapter和vmware svga适配器。 我们正在使用Horizon 6.2运行vsphere 6。 以上来自于谷歌翻译 以下为原文 Im trying to build a Windows 10 vm for Horizon and I cant install the nvidia grid drivers for vGPU use. I have a working Windows 7 vm that has the shared PCI device configured for our K1 cards using the k120q profile so I know the card is working. I added the shared PCI device to Windows 10 and tried to install the drivers (361.75) and it tells me "This graphics driver could not find compatible graphics hardware." The device manager shows a Microsoft Basic Display Adapter and the vmware svga adapter. We are running vsphere 6 with Horizon 6.2. |
没关系,我模糊地回忆起上次驱动程序存在一些问题,这使得我使用vpshere ESX驱动程序附带的Windows驱动程序。
显然,Nvidia Grid vGPU驱动程序与Nvidia Quadro-Grid驱动程序不同。 根据设备ID,我认为它与标准驱动程序不支持的vGPU配置文件有关。 我回去下载了最新的vpshere ESX驱动程序,随附的Windows驱动程序安装在我的Windows 10 VM上。 以上来自于谷歌翻译 以下为原文 Never mind, I vaguely recalled there being some issue with the driver last time that made me use the driver for windows that came with the vpshere ESX drivers. Apparently the Nvidia Grid vGPU drivers are not the same as the Nvidia Quadro - Grid drivers. Based on the device IDs, I think it has something to do with the vGPU profiles not being supported in the standard drivers. I went back and downloaded the latest vpshere ESX drivers and the windows drivers that came with it do install on my Windows 10 VM. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3151 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3565 浏览 4 评论
GMT+8, 2025-1-13 07:04 , Processed in 0.425249 second(s), Total 41, Slave 36 queries .
