STM32F103 采用GCC+ Eclipse 编译工具,编译ST官方的IOToggle 程序报以下错误,求解!
./Libraries/CMSIS/CM3/DeviceSupport/ST/STM32F10x/system_stm32f10x.o: In function `SystemInit': E:workspaceGCCTESTDebug/../Libraries/CMSIS/CM3/DeviceSupport/ST/STM32F10x/system_stm32f10x.c:213: multiple definition of `SystemInit' ./User/system_stm32f10x.o:E:workspaceGCCTESTDebug/../User/system_stm32f10x.c:213: first defined here ./Libraries/CMSIS/CM3/DeviceSupport/ST/STM32F10x/system_stm32f10x.o: In function `SystemCoreClockUpdate': E:workspaceGCCTESTDebug/../Libraries/CMSIS/CM3/DeviceSupport/ST/STM32F10x/system_stm32f10x.c:307: multiple definition of `SystemCoreClockUpdate' ./User/system_stm32f10x.o:E:workspaceGCCTESTDebug/../User/system_stm32f10x.c:307: first defined here c:/users/kevin li/mentorgraphics/sourcery_codebench_lite_for_arm_eabi/bin/../lib/gcc/arm-none-eabi/4.8.1/../../../../arm-none-eabi/lib/thumb2libc.a(lib_a-init.o): In function `__libc_init_array': init.c.text+0x3c): undefined reference to `_init' collect2.exe: error: ld returned 1 exit status cs-make: *** [GCCTEST.elf] Error 1 09:38:43 Build Finished (took 10s.198ms) |
6个回答
看调试输出信息是重复定义了,找找看哪定义了
我用MDK5.1可以编译, 你看看你的设置是否出错了, 看看哪重复定义了
没有用过GCC+ Eclipse 编译工具,看看是不是你的路径没有定义好
你重复添加同一个文件了吧
我看也是路径不对
STM32串口接受中断使用C++STL中的queue导致所有中断失效
1196 浏览 1 评论
2501 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1265 浏览 0 评论
3370 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3151 浏览 4 评论
GMT+8, 2025-1-26 14:29 , Processed in 0.450364 second(s), Total 50, Slave 44 queries .
