你好,
我在哪里可以配置Cmod,如果它是由ezi2c(CSD [ 0 ]。shield_pad)? 我不知道如果我能改变ezi2c接口渣打银行[ 1 ],因为在evalkit(4045)看起来对我来说,ezi2c与渣打银行[ 0 ]工作: 谢谢您 编辑:如果我做的自动分配,其分配CMOD P4 [ 3 ] = CSD [ 0 ]。CSH 有什么区别,CSD [ 0 ]。CSH CSD的[ 0 ]。shield_pad? 以上来自于百度翻译 以下为原文 Hello, where can I configure Cmod, if it is used by EZI2C (CSD[0].shield_pad)? I am not sure if I can change EZI2C Interface to SCB[1], because on the Evalkit(4045) it looks for me that the EZI2C is only working with SCB[0]: thank you EDIT: If I do auto-assign, it assign Cmod to P4[3] = CSD[0].csh what's the difference CSD[0].csh to CSD[0].shield_pad ? |
6个回答
你好,
EZI2C可以配置在SCB块0和1中。只是确保u***-i2c桥可与PC机通信(假设你使用调谐器GUI) 在评估套件,我假设你正在使用的试剂盒黄体酮作为u***-i2c桥。这可能是您使用ESCI2C的SCB0块的原因。 对于不同的PSoC器件CMOD连接,指的是http://www.cypress.com/file/46081/download 113页 谢谢,Shanmathi 以上来自于百度翻译 以下为原文 Hi, EzI2C can be configured in SCB blocks 0 and 1. Just ensure that USB-I2C bridge is available to communicate with PC (Assuming you use tuner GUI) in Eval kit, I assume you are using Kit-prog as USB-I2C bridge. This may be the reason you are using SCB0 block for EzI2C. Regarding Cmod connections for various PSoC devices, refer to page 113 of http://www.cypress.com/file/46081/download Thanks, Shanmathi |
60user14 发表于 2018-9-5 18:01 我在文件中找到了关于CMOD的内容: 但是差异P4〔3〕CSD〔0〕。CSH到P4〔1〕CSD〔0〕。 以上来自于百度翻译 以下为原文 I've found follow in the document, regarding CMOD: but the difference P4[3] CSD[0].csh to P4[1] CSD[0].shield_pad is not explained? |
嗨,彼埃尔, 有三个引脚之间没有差异(P4 [ 1 ] [ 2 ],P4,P4 [ 3 ])。 CMOD可以连接到3个引脚中的任何一个。 谢谢,Shanmathi 以上来自于百度翻译 以下为原文 Hi Pierre, There is no difference between the three pins (P4[1], P4[2], P4[3]). Cmod can be connected to any one of the 3 pins. Thanks, Shanmathi |
在三个引脚(P4〔1〕、P4〔2〕、P4〕〔3〕之间没有差别。 CMOD可以连接到3个引脚中的任何一个。 好啊。很好,但我想知道为什么名字是不同的?见附件图像: 以上来自于百度翻译 以下为原文 There is no difference between the three pins (P4[1], P4[2], P4[3]). ok. good, but even I'm wondering why the names are different?? see attached image: |
cmh11 发表于 2018-9-5 18:33 没有人知道上面的名字(CMOD,…CSH,…SelddPad)的原因吗? 以上来自于百度翻译 以下为原文 does nobody knows above reason about the ending-names (...cmod, ...csh, ...shield_pad)? |
嗨,彼埃尔, 命名是关于PACSENSE IP中的焊盘。 我认为名字不必担心。你可以很好地使用这三个引脚中的任何一个连接Cmod。 谢谢,Shanmathi 以上来自于百度翻译 以下为原文 Hi Pierre, The naming is with respect to the pads in CapSense IP. I think that there is no worry regarding the names. You could very well use either of the three pins to connect Cmod. Thanks, Shanmathi |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1265浏览 2评论
GMT+8, 2025-3-6 23:15 , Processed in 0.872617 second(s), Total 54, Slave 49 queries .
