扫一扫,分享给好友
大家好,
我正在通过以下链接阅读View 6.2的GRID部署指南: https://www.vmware.com/files/pdf/products/horizon/grid-vgpu-deployment-guide.pdf 在第17页,它为几个服务器制造商提供了BIOS建议。 它建议禁用SuperMicro的“Above 4G Decoding”。 对于Dom0为32位的XenServer 6.2,这是必需的。 在64位Dom0的XenServer 6.5中,没有必要禁用此设置。 vmkernel是64位所以我想知道是否真的有必要禁用此设置? 在我们的SuperMicro测试中,禁用此设置会生成“检测到PCI资源不足”警告。 所有SuperMicro支持文章都建议启用“Above 4G Decoding”来解决此警告消息。 BIOS是最新版本,SuperMicro直接出厂,我们在XenServer 6.2和6.5上使用相同型号的GRID而没有问题。 如果您有使用vSphere 6的“Above 4G Decoding”设置和使用vGPU查看的经验,请提供建议。 谢谢! 理查德 以上来自于谷歌翻译 以下为原文 Hi All, I am reading through the GRID deployment guide for View 6.2 at the following link: https://www.vmware.com/files/pdf/products/horizon/grid-vgpu-deployment-guide.pdf On page 17, it gives the BIOS recommendations for several server manufacturers. It advises to disable the "Above 4G Decoding" for SuperMicro. This was necessary for XenServer 6.2 where Dom0 was 32bit. In the 64bit Dom0 of XenServer 6.5, it is not necessary to disable this setting. The vmkernel is 64 bit so I want to know if it is really necessary to disable this setting? On our test SuperMicro, disabling this setting generates an "Insufficient PCI Resources Detected" warning. All the SuperMicro support articles advise to enable "Above 4G Decoding" to resolve this warning message. The BIOS is at the latest version and SuperMicro is straight from the factory and we've used this same model for GRID on XenServer 6.2 and 6.5 without issue. If you have experience with the "Above 4G Decoding" setting for vSphere 6 and View with vGPU, please advise. Thanks! Richard |
7个回答
嗨理查德,
当你启用它时发生了什么? 你和SMicro讨论过吗? 以上来自于谷歌翻译 以下为原文 Hi Richard, What happened when you did leave it enabled? Did you discuss with SMicro? |
我遇到了完全相同的问题。
你回去并启用了那个设置吗? 您的GRID卡对vGPU仍然可以正常工作吗? 以上来自于谷歌翻译 以下为原文 I'm running into exactly the same issue. Did you go back and enable that setting? Do your GRID cards still work fine for vGPU? |
大家好,
我被解决了其他一些紧急问题,但是当我回到这个项目时,我会发布我的结果。 干杯, 理查德 以上来自于谷歌翻译 以下为原文 Hi All, I have been pulled onto some other urgent issues but I'll post my results when I get back to this project. Cheers, Richard |
你能提供的任何信息都会很棒。
我此刻已经死在水中了。 如果由于某种原因这不能与Supermicro一起工作,我需要知道,所以我可以继续前进。 非常感激。 以上来自于谷歌翻译 以下为原文 Any info you could provide would be great. I'm dead in the water at the moment. If this doesn't work with Supermicro for some reason I need to know so I can move on. Much appreciated. |
发现问题:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2050443 不支持4GB以上的MMIO。 如果“将4G以上解码”更改为禁用,Supermicro必须找到一种允许服务器完全启动的方法。 以上来自于谷歌翻译 以下为原文 Found the issue: http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2050443 MMIO above 4GB not supported. Supermicro has to find a way to allow the server to fully boot if "Above 4G Decoding" is changed to disabled. |
以下是supermicro的答案:http://www.supermicro.com/support/faqs/faq.cfm?faq = 2004
vGPU需要4g以上的解码才能启用,而vDGA要求它禁用 以上来自于谷歌翻译 以下为原文 here is the answer from supermicro: http://www.supermicro.com/support/faqs/faq.cfm?faq=20016 vGPU requires above 4g decoding to be ENABLED, while vDGA requires it to be DISABLED |
解决VMware众所周知的bug并不是完整的答案。
请关注:https://gridforums.nvidia.com/default/topic/808/nvidia-grid-drivers/grid-3-0-successfully-installs-on-esxi-6-0-2-with-m60-gpu- 但是,无法对校验通过,NVIDIA-SMI / 提取到NVidia KB:http://nvidia.custhelp.com/app/answers/detail/a_id/4119/ 以上来自于谷歌翻译 以下为原文 It is not complete answer to solve VMware well known bug. Follow: https://gridforums.nvidia.com/default/topic/808/nvidia-grid-drivers/grid-3-0-successfully-installs-on-esxi-6-0-2-with-m60-gpu-but-fails-to-verify-via-nvidia-smi/ Extracted to NVidia KB: http://nvidia.custhelp.com/app/answers/detail/a_id/4119/ |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3176 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3587 浏览 4 评论
GMT+8, 2025-2-24 14:51 , Processed in 1.184875 second(s), Total 108, Slave 92 queries .
