我通过PLTS中的“自动夹具移除”实用程序运行一堆直通文件,并保存了去嵌入的夹具文件。
它适用于大多数文件。 在其他人我得到一个错误,说明“源频率的长度。数据不相同,导出无法实现”。 据我所知,s2p文件看起来很好。 更具体地说,我正在导入附加的thru文件。 然后使用自动夹具移除并加载相同的thru文件以获取去嵌入的夹具文件(1和2),并将其写出。 现在,如果我取消选中“输出去嵌入的夹具文件”,那么实用程序似乎工作得很好。 该图看起来像预期的那样。 我只是在尝试写出文件时遇到错误。 PLTS的版本是5.500。 为方便起见,我还附上了一个s2p文件。 非常感谢任何帮助,谢谢。 以上来自于谷歌翻译 以下为原文 I am running a bunch of thru files through the "automatic fixture removal" utilitie in PLTS, and saving out the de-embeded fixture files. It works just fine on most of the files. On others I am getting an error stating "the length of the source freq. and data are not identical, export can not be achieved". The s2p files seem fine as far as I can tell. To be more specific I am importing the attached thru file. Then using the automatic fixture removal and loading the same thru file to get the de-embeded fixture files (1 and 2), and writing them out. Now if I uncheck the "Output De-embeded Fixture Files" the utilitie seems to work just fine. The graph looks as expected. I only get the error when trying to write the files out. The version of PLTS is 5.500. I have also attached one of the s2p files for your convenience. Any help would be greatly appreciated, thanks. 附件 |
我尝试在你的文件上使用AFR,它在PLTS 2012中运行良好。我看到开始和步进频率略有不同,我知道在一些旧版本的PLTS AFR中严格的开始和步频是相同的,
这在PLTS 5.5版本(可能是5.503)或PLTS 2011的后期发生了变化。我已将拆分文件附加到这篇文章中。 如果点不是问题,我建议使用10 MHz或20或50 MHz的开始和步进频率。 fixt_2.s2p144.5 KB 以上来自于谷歌翻译 以下为原文 I tried using AFR on your file and it worked fine in PLTS 2012. I saw that the start and step frequencies were slightly different and I know that in some of the older versions of PLTS AFR was strict about the start and step frequencies being identical and that was changed late in the PLTS 5.5 versions (probably 5.503) or PLTS 2011. I've attached the split files to this post. If points are not an issue, I would recommend using a start and step frequency of either 10 MHz or maybe 20 or 50 MHz. 附件
yweyerwq 发表于 2018-9-4 17:08 感谢您对此进行调查。 我猜它可能是一个旧版本的东西。 再次感谢您的帮助和快速回复。编辑:Lumberjack于2012年3月21日上午9:10 以上来自于谷歌翻译 以下为原文 Thanks for looking into it. I was guessing that it might be an older version thing. Again thanks for your help and quick reply. Edited by: Lumberjack on Mar 21, 2012 9:10 AM |
1351 浏览 0 评论
2405 浏览 1 评论
2234 浏览 1 评论
2088 浏览 5 评论
2981 浏览 3 评论
1315浏览 1评论
795浏览 0评论
1101浏览 0评论
1351浏览 0评论
GMT+8, 2025-2-1 17:47 , Processed in 1.124676 second(s), Total 46, Slave 41 queries .
