请原谅,如果我在某处被问到,我使用的是TCP IP堆栈V5.42.08设备PIC24FJ256+Enc28。当我启用DHCP服务器,然后将板连接到我的PC(直接到以太网端口)时,它总是给我的PC分配IP地址169254.0.100和子网掩码255.255.0.0。我想要DHCP服务器屁股。我的子网掩码255.255.255.0,我如何改变?我在文件“DHCPS.C′://选项:子网掩码UPDPT(DHCPA子网掩码))中,在DHCP子网掩码中定义了“DHCP .H”:*定义DHCPA-子网掩码(1U)//DHCP1子网掩码类型,这是我必须更改的部分吗?是否将其更改为(0U)或(2U)以获得子网掩码255.255.255.0?
以上来自于百度翻译 以下为原文 Pardon me if this has been asked somewhere, I'm using TCP IP Stack v5.42.08 Device PIC24FJ256 + ENC28. When I enabled DHCP server then connect the board to my PC (directly to the ethernet port), it always assign my PC with IP address 169.254.0.100 and subnet mask 255.255.0.0. I want the DHCP server assign me subnet mask 255.255.255.0 instead, how do I change that? I found in file 'DHCPs.c': // Option: Subnet Mask UDPPut(DHCP_SUBNET_MASK); Where DHCP_SUBNET_MASK is defined in 'DHCP.h': #define DHCP_SUBNET_MASK (1u) // DHCP_SUBNET_MASK Type Is this the part that I must change? Do I change it to (0u) or (2u) to obtain subnet mask 255.255.255.0? |
4个回答
也许它用你的面具来提供DHCP
以上来自于百度翻译 以下为原文 Maybe it uses your mask for the dhcp offer // Option: Subnet Mask UDPPut(DHCP_SUBNET_MASK); UDPPut(sizeof(IP_ADDR)); UDPPutArray((uint8_t*)&AppConfig.MyMask, sizeof(IP_ADDR)); |
AWW是的,在我把设备默认IP地址改为192.1681.101“C型”地址后,现在DHCP服务器将我的PC分配给另一个“C型”地址192.1681.100和子网255.255.255.0,但奇怪的是,现在我无法通过键入主机名“http://MCHPC板”来访问该板,浏览器搜索“www. MCH”。我以前可以用“B型”地址来做这件事。
以上来自于百度翻译 以下为原文 Aww yeah, after I changed device default IP address to 192.168.1.101 "type C" address, now the DHCP server assign my PC with another "type C" address 192.168.1.100 and subnet 255.255.255.0. But, strange now I cannot access the board by typing host name "http://mchpboard", the browser search "www.mchpboard.com" instead. while I can do that previously with "type B" address. |
N.B.“192.1681.101”是“C型”地址。对不起,对您的其他问题无能为力。
以上来自于百度翻译 以下为原文 n.b. "192.168.1.101" is a "Type C" address. Sorry, can't help with your other problem. |
好的,修正192.1681.101是“C型”地址,我已经编辑了这个帖子。
以上来自于百度翻译 以下为原文 Ok, correction 192.168.1.101 is "Type C" address, I've edited the post. |
5248 浏览 9 评论
2037 浏览 8 评论
1957 浏览 10 评论
3218 浏览 3 评论
2265 浏览 5 评论
788浏览 1评论
679浏览 1评论
608浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 02:21 , Processed in 1.410723 second(s), Total 84, Slave 68 queries .
