嗨,我使用和声V2.06.有一个函数,如果字符串长,字符串会自动包装在一个标签中?或者,有可能在字符串中添加一个新的行字符“n”来包装一个字符串吗?目标是有一个文本区域,在那里我可以使用一个字符串超过一个文本行。谢谢和最好的问候Markus。
以上来自于百度翻译 以下为原文 Hi I use HARMony v2.06 Is there a function that a string will automatically wraped in a lable if the string is to long? Or is there a possibility to add a new line character 'n' to a string to wrap a string? The goal ist to have an text area, where I can use one string over more then one text lines. thanks and best regards Markus |
4个回答
标签小部件不自动包装。但是您应该能够将新的行n字符插入到字符串AsETE上,以开始新的行。字符串资产W/新行在标签和按钮小部件上得到支持。如果有问题,请告诉我。
以上来自于百度翻译 以下为原文 The label widget doesn't auto wrap. But you should be able to insert the new line 'n' character to a string asset to start on a new line. String assets w/ new line are supported on label and button widgets. Let me know if you have problems getting this to work. |
感谢,但它似乎不与“n”如何我可以添加字符“n”到一个字符串在图形作曲家?把这个文本包在这里n这是第二行“这是正确的还是字符‘n’是怎么写的?
以上来自于百度翻译 以下为原文 Thanks but it does not seem to work with 'n' How can I add the character 'n' to a string in the graphic composer? "Wrap this text here n this is the seconde line" Is this correct or how has the character 'n' be written? Attached Image(s) |
啊,我明白了。首先我用的是文本字段。看起来,一个文本字段不支持'n'使用而不是一个标签,它支持'n '特性感谢。
以上来自于百度翻译 以下为原文 Ah I got it. First I was using a Textfield. It looks like, that a Text field does not support 'n' Use instead a Label, this supports the 'n' character Thanks |
是的,只有按钮和标签小部件支持多行字符串。对于其他小部件,可以在顶部覆盖标签控件。
以上来自于百度翻译 以下为原文 Yes, only button and label widgets support multi-line strings. For other widgets, you can overlay a label widget on top. |
5303 浏览 9 评论
2065 浏览 8 评论
1972 浏览 10 评论
3239 浏览 3 评论
2279 浏览 5 评论
827浏览 1评论
715浏览 1评论
663浏览 1评论
716浏览 0评论
615浏览 0评论
GMT+8, 2025-1-23 04:46 , Processed in 0.937742 second(s), Total 49, Slave 44 queries .
