1,赛克的首要任务是什么?在我的系统中,我使用IMO的SyTobe更新RTC,当系统中还有其他ISR时,SyToRIRQ可以抢占其他IRQ吗?
如果无法抢占,则由SyTobe更新的RTC不准确。 2,PSOC4100S能支持中断抢占吗?如何使用它。 谢谢。 以上来自于百度翻译 以下为原文 1, what's the priority of systick? in my system i using IMO's systick to update RTC, when there is other ISR in system, can the systick IRQ preempt other IRQ? if can't occure preemption, the RTC being updated by systick is not accurate. 2, can PSoC4100s support interrupt preempt? how to use it. thanks. |
5个回答
摘录:皮质-M0设备通用用户指南
当处理器正在执行异常处理程序时, 异常可以抢占异常处理程序,如果它的优先级是 高于被处理异常的优先级。 当一个异常抢占另一个异常时,异常被称为 嵌套异常。 你不能“使用”这个特征,它是固有的。 SyBLE中断优先级是可配置的。 鲍勃 以上来自于百度翻译 以下为原文 Excerpt from Cortex™-M0 Devices Generic User Guide When the processor is executing an exception handler, an exception can preempt the exception handler if its priority is higher than the priority of the exception being handled. When one exception preempts another, the exceptions are called nested exceptions. You cannot "use" ths feature, it is inherant. The SysTick interrupt priority is configurable. Bob |
在PSoC,如何配置SyBub的优先级?我只能看到GPIO或外围设备的冲突。 以上来自于百度翻译 以下为原文 in PSoC how to configure the priority of SysTick? i just can see GPIO or peripheral's interrrupts. |
你好,棋盘, 请使用cyintsetpriority(cy_int_systick_irqn,1)设置cy_int_systick_irqn优先1.。更多的细节可在PSoC 4系统参考指南中获得 最好的问候, 吉娜玛丽 以上来自于百度翻译 以下为原文 Hello Qipan, Please make use of CyIntSetPriority(CY_INT_SYSTICK_IRQN,1) to set the priority of CY_INT_SYSTICK_IRQN to 1. More details are available in PSoC 4 System Reference Guide Best Regards, Geona Mary |
zhushanyu262 发表于 2018-9-3 16:43 好吧,这是我的安慰。 现在我从SyTobe切换到Time2(来自WCO,因为ILO不准确),对于我来说,Time2的优先级是未知的,可以设置Time2的优先级。 *定义CythIn NMIIIrqn(2U)/*不可屏蔽中断*/*定义CythIn HythOrth.TyrqIrqn(3U)/*硬故障中断*/*定义CythIntIsValCalqIrqn(11U)/*SV调用中断*/*定义CythIn PypNysVIVIrqn(14u)/*pEnd中断中断*/*定义CythIn ySysKyIrqn(15U)/*系统TIKE中断*/* 以上来自于百度翻译 以下为原文 OK, it is soltuion for me. Now i switch from systick to timer2(derived from wco, as ilo is not accurate), as to me the priority of timer2 is unknown, can i set the priority of timer2.
vywywerwa 发表于 2018-9-3 16:56 你好,棋盘, 请使用中断选项卡来更改在设计中放置的中断服务程序(ISRS)的优先级。此编辑器是设计范围资源文件(CydWR)的一部分。 最好的问候, 吉娜玛丽 以上来自于百度翻译 以下为原文 Hello Qipan, Please make use of the Interrupts tab to change the priority of interrupt service routines (ISRs) placed in your design. This editor is part of the design wide resources file (cydwr). Best Regards, Geona Mary |
759个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-23 12:06 , Processed in 1.038383 second(s), Total 106, Slave 90 queries .
