我有一个要求睡觉和唤醒使用CAPSENSE按钮。这是可能的吗?当按下时,唯一可以运行的东西(几乎一切都处于睡眠模式)是唤醒的CAPSENSE按钮。
以上来自于百度翻译 以下为原文 I have a requirement to sleep and wake using a CapSense button. Is this possible? When pressed the only thing that can be running (almost everything is in sleep mode) is the CapSense button to wake. |
嗨,安得烈,
对。这是可能的。工作流程和你的想法非常相似。 如果没有触摸指定超时,该芯片将转向低速扫描模式。一旦联动按钮触动,该芯片将转向快速扫描(主动)模式。 我们有一些关于它的示例代码。例如: http://www.cypress.com/documentation/code-examples/ce210488-lp-capsense-buttons http://www.cypress.com/documentation/code-examples/ce214022-low-power-capsense-buttons 谢谢, 赖安 以上来自于百度翻译 以下为原文 Hi Andrew, Yes. It's possible. The work flow is much similar with your thought. If there is no touch for a specified timeout, the chip will turn to low speed scan mode. Once the ganged button touched, the chip will turn back to fast speed scan(active) mode. And we have some example code about it. For example: http://www.cypress.com/documentation/code-examples/ce210488-lp-capsense-buttons http://www.cypress.com/documentation/code-examples/ce214022-low-power-capsense-buttons Thanks, Ryan |
757个成员聚集在这个小组
加入小组2131 浏览 1 评论
1873 浏览 1 评论
3692 浏览 1 评论
1809 浏览 6 评论
1556 浏览 1 评论
717浏览 2评论
505浏览 2评论
463浏览 2评论
416浏览 2评论
1104浏览 2评论
GMT+8, 2025-1-30 13:29 , Processed in 0.969621 second(s), Total 74, Slave 59 queries .
