嗨,我在GUI中使用GROPBOX来分组一些Objjcts。即使边界类型设置为“No.1”,GROMPBOX控件也始终有一个边框。这是一个bug吗?或者Gypbox小部件不支持无边界类型?和谐版本= V2.06感谢和关注马库斯
以上来自于百度翻译 以下为原文 Hi I use in my GUI a groupbox to group some obejcts. This Groupbox widget has always a border even though the border type is set to NONE. Is this a bug? Or does the GroupBox Widget not support None border type? HARMony version = v2.06 thanks and regards Markus |
嗨,Markus,群组窗口小部件总是在它周围画一个“框”。分组框控件的边框属性可以为整个小部件启用/禁用一个分离的外部边框,就像其他小部件一样。作为替代,您可以使用面板小部件来分组窗口小部件而不显示边框。将这些小部件作为子元素添加到面板小部件。面板小部件不支持像组框控件那样的文本字符串,但是您可以添加一个标签控件来完成。谢谢,Ed @ Microchip
以上来自于百度翻译 以下为原文 Hi Markus, The group box widget will always draw a 'box' around it. The border property for the group box widget enables/disables a separate outside border for the entire widget, just like the other widgets. As an alternative, you can use a panel widget to group widgets without displaying a border. Add these widgets as children to the panel widget. The panel widget does not support a text string like the group box widget, but you can add a label widget to do that. Thanks, Ed @ Microchip |
5244 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
3214 浏览 3 评论
2261 浏览 5 评论
779浏览 1评论
672浏览 1评论
598浏览 1评论
682浏览 0评论
579浏览 0评论
GMT+8, 2024-12-25 14:54 , Processed in 1.012259 second(s), Total 46, Slave 40 queries .
