最近在学习 DCMI接口 通过DMA将DCMI接口中的数据传送到内存中的一个数组中,DCMI 和 DMA都有自己的中断入口,DCMI有行同步中断 和帧同步中断,这两个中断都可以自动进入,但DMA2的传送完毕中断就是进不去,我知道DCMI中有个函数可以置位CAPTURE位,这个位可以通知DMA起动传送,我置为了可DMA2的中断就是没响应!我用的是MDK,有知道的朋友能否指点一下!
8个回答
DMA 的 Stream 和 channel 连接的外设是有规定的 手册里面有写 不能随便换
DMA_ITConfig(DMA2_Stream1,DMA_IT_TC,ENABLE);//传送完成中断 DMA_Init(DMA2_Stream1, &DMA_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); 另外我这边也是用的fsmc驱动tft 遇到了问题 就是图像数据 传不完整 |
楼主可否贴上源码
void DCMI_Config(void)
{ DCMI_InitTypeDef DCMI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; DMA_InitTypeDef DMA_InitStructure; //使能DAMI 的GPIO时钟 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOC, ENABLE); //使能DCMI时钟 RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE); //连接DCMI管脚到AF13功能 GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_DCMI); GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_DCMI); // DCMI GPIO 配置 // D0..D4(PC6/7/8/9/11) GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOC, &GPIO_InitStructure); // D5..D7(PB6/8/9), VSYNC(PB7) GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9; GPIO_Init(GPIOB, &GPIO_InitStructure); // PCLK(PA6) HSYNC(PA4) GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); // DCMI 配置 DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous; DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware; DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Falling; DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High; DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High; DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame; DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b; DCMI_Init(&DCMI_InitStructure); // 配置 DMA2 传输数据从DCMI 到 LCD // 使能 DMA2 时钟 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); //DMA2 Stream1 配置 DMA_DeInit(DMA2_Stream1); DMA_InitStructure.DMA_Channel = DMA_Channel_1; DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS; DMA_InitStructure.DMA_Memory0BaseAddr = FSMC_LCD_ADDRESS; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; DMA_InitStructure.DMA_BufferSize = 1; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA2_Stream1, &DMA_InitStructure); } 你看下这个配置,这是DCMI驱动ov7670的配置 |
应该是设置DMA传输有误。
DCMI接口接收到数据后通知DMA需要DCMI_CaptureCmd(ENABLE)来设置 CR寄存器的CAPTURE位。看看是不是程序跑飞了?推荐贴上代码
的DMA传送是循环模式的,不会产生传输完成中断,但你可以设置帧中断
//DMA2 Stream1 配置 DMA_DeInit(DMA2_Stream1); DMA_InitStructure.DMA_Channel = DMA_Channel_1; DMA_Init(DMA2_Stream1, &DMA_InitStructure); 我想问下,STM32的DCMI接口进行DMA传输非得这样配置吗?可不可以用DMA1或者另外的通道?我用另外的通道一直行不通 |
你的DMA中断没有设置
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); 在DMA初始化完成之后把这几句加上,相应的部分要修改。你在试试 |
881 浏览 0 评论
国产NSI1300D05-DSWVR放大芯片放大增益8.2或41的问题
895 浏览 0 评论
STM32串口接受中断使用C++STL中的queue导致所有中断失效
8670 浏览 1 评论
3394 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1379 浏览 0 评论
GMT+8, 2025-2-24 23:39 , Processed in 0.510380 second(s), Total 52, Slave 47 queries .
