周二 九月 24, 2013 15:27:13: Loaded macro file: D:Program Files (x86)IAR SystemsEmbedded Workbench 6.5armconfigflashloaderST
FlashSTM32F2xxxx.mac 周二 九月 24, 2013 15:27:14: JLINK command: ProjectFile = D:Program Files (x86)IAR SystemsEmbedded Workbench 6.5armexamplesST STM32F2xxIAR-STM32F207ZG-SKBuzzersettingsBuzzer_Flash Debug.jlink, return = 0 周二 九月 24, 2013 15:27:14: Device "STM32F207ZE" selected (512 KB flash, 64 KB RAM). 周二 九月 24, 2013 15:27:14: DLL version: V4.62 周二 九月 24, 2013 15:27:14: Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52 周二 九月 24, 2013 15:27:14: Selecting SWD as current target interface. 周二 九月 24, 2013 15:27:14: JTAG speed is initially set to: 32 kHz 周二 九月 24, 2013 15:27:14: Found SWD-DP with ID 0x2BA01477 周二 九月 24, 2013 15:27:14: Found SWD-DP with ID 0x2BA01477 周二 九月 24, 2013 15:27:14: TPIU fitted. 周二 九月 24, 2013 15:27:14: ETM fitted. 周二 九月 24, 2013 15:27:14: FPUnit: 6 code (BP) slots and 2 literal slots 周二 九月 24, 2013 15:27:14: Found Cortex-M3 r2p0, Little endian. 周二 九月 24, 2013 15:27:14: Hardware reset with strategy 0 was performed 周二 九月 24, 2013 15:27:14: Initial reset was performed 周二 九月 24, 2013 15:27:14: 712 bytes downloaded and verified (4.46 Kbytes/sec) 周二 九月 24, 2013 15:27:14: Warning: Verify error at address 0x20000002, target byte: 0x00, byte in file: 0x02 周二 九月 24, 2013 15:27:14: Warning: Verify error at address 0x20000003, target byte: 0x00, byte in file: 0x20 //此处省略好多上面四行的类似信息 周二 九月 24, 2013 15:27:14: Warning: Too many verify errors, only the first 200 are displayed 周二 九月 24, 2013 15:27:18: Fatal error: There were warnings during download of FLASH loader, see Log Window Session aborted! 周二 九月 24, 2013 15:27:18: Failed to load flash loader: D:Program Files (x86)IAR SystemsEmbedded Workbench 6.5armconfigflashloaderST FlashSTM32F2xxxx.out 周二 九月 24, 2013 15:27:18: Failed to load flash loader: D:Program Files (x86)IAR SystemsEmbedded Workbench 6.5armconfigflashloaderST FlashSTM32F205xE.flash 上面是提示的错误,环境IAR6 j-link v8 stm32f207zgt6 |
9个回答
是不是你的工程配置有问题,你重新选择一下MCU类型。
有没有锁定过FLASH,估计你写保护了
同一楼,感觉是工程配置有问题,建议楼主仔细检查一下!!
回复第 5 楼 于2013-09-25 09:39:01发表:
同一个工程以前的板子可以,现在的不行,应该不是配置的问题 用stvp能读出来但是不能写,而且读出来的也很奇怪是从0x08008000开始有数据之前的都是FF 这钟一般是写保护了,估计你启动了写保护,但是STLINK是没法擦除写保护的,需要用ISP方式擦除一下。 |
先不要用STlink,用串口ISP擦除一下,再下载可能就好用了
看提示是FLASH写不进去,建议看看是不把FLASH保护了
一般就是你工程配置的问题,选择正确的芯片。实在不行的用flash demo这个软件,擦除内部flash。然后再下载试试
谢谢各位,用stvp+stlink不明不白的解决了
2162 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1997 浏览 3 评论
4593 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
2140 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
2659 浏览 1 评论
GMT+8, 2024-12-24 10:18 , Processed in 0.717908 second(s), Total 92, Slave 75 queries .
