我下面的英镑LWB STM扩展板用户指南建立和下载演示软件:“snip.scan-lsrsterling_00950-threadx-netx-sdio下载download_apps跑”
失败了: 下载应用程序… 下载WiFig固件…在扇区1大小94… 进程无法访问文件,因为另一个进程正在使用它。 制作.exe [ 1 ]:**[WiFixStimeCysLoop]错误1 工具/文件/ wiced_apps。MK:350:目标的wifi_firmware_download配方失败 Ex.EXE(1):***等待未完成的工作… 未检测到任何变化 使:***[MNIONAPP]错误2 MaFixFiel: 351:目标“MeNIApp”失败的配方 09:58:05搭建完成(取6S.327毫秒) SDK是6.21。 你对错误做了什么建议? 谢谢 结仇 以上来自于百度翻译 以下为原文 i am following the Sterling-LWB STM expansion board user guide to build and download the demo software: "snip.scan-LSRSTERLING_00950-ThreadX-NetX-SDIO download download_apps run" it failed: Downloading Application ... Downloading WIFI_FIRMWARE ... at sector 1 size 94... The process cannot access the file because it is being used by another process. make.exe[1]: *** [WIFI_FIRMWARE_DOWNLOAD] Error 1 tools/makefiles/wiced_apps.mk:350: recipe for target 'WIFI_FIRMWARE_DOWNLOAD' failed make.exe[1]: *** Waiting for unfinished jobs.... No changes detected make: *** [main_app] Error 2 Makefile:351: recipe for target 'main_app' failed 09:58:05 Build Finished (took 6s.327ms) The SDK is 6.21. Any ideas can you give on what is done wrong? Thanks Jieqiu |
5个回答
附件是修改的演示和平台文件,请利用这个来构建例子。在演示代码已经成功建立并使用以下WICED 6.2测试 snip.scan-lsrsterling_00950-threadx-netx-sdio下载download_apps rundemo.sterling_demo-lsrsterling_00950-threadx-netx-sdio下载download_apps 最好的问候, 盖茨-莱尔德-费 sterlingdemoverification_2018_06_19.zip 1.4兆字节 以上来自于百度翻译 以下为原文 Attached are modified demo and platform files, please utilize this to build the example. The code in the demo has been successfully built and tested in WICED 6.2 using the following
Best Regards, G. Gates - Laird FAE |
谢谢greg.gates@lairdtech.com 谢谢你的修改和文件演示平台。 我重复了演示。是没有任何问题的snip.scan。然而,我可以下载demo.syterling.demo。当它运行时,它显示: … WICED vwiced_006.002.001.0002出发 平台lsrsterling_00950初始化 启动th5.x v5.8 初始化NETX V5.10Sp3 创建包池 无线局域网MAC地址:00:25:钙:09:b5:3d WLAN固件:WL0: 4月30日2018 04:14:19版本7.45.9850(R68715CY)FWI D 01-83FCDB9 WLAN CLM:API:12.2数据:91.39编译器:1.27.4CLMIPION:1.33.3CR EATI:2018-04-1122:31:21 应用DCT 主机名:sterling.tiwiconnect.com apiendpoint:电梯 TCPPORT:80 SecurePort:443 交通:http clientId: apikey: userkey: 密钥: 设备信息 设备名称:925 WICED载板 devicetypename:lrd_sterlingevb_demokit_0_1_0 devicetypever:0.1.0 xfrmname:lrd_sterlingevb_elv_0_1_0 xfrmver:0.1.0 firmwarename:lrd_sterlingevb_simpledemo_1_0_0 firmwarever:1.0.0 预期的SPI芯片ID:D5 D4检测: 00:00: 2.834000 gki_exception():任务状态表 0:00:2.839000 GKIY异常65524无法分配缓冲池 00∶00:2.845000 GKIGCREATEY任务FUNC= 0x803CDBD ID=1 Name=BTU堆栈=0x0堆栈大小=4096 00:00: 02.853000 gki_create_task thread_id失败(8),但是! 00∶00:2.858000 GKIGCREATEY任务FUNC= 0x803E585 ID=0 Name=HCISU堆栈=0x0 STA CKSIZE=3072 00:00: 2.867000 gki_create_task thread_id失败(8),hcisu! *等待,没有WiFi网络配置* 因为这个问题,我没有看到的被打开。 当做 结仇 以上来自于百度翻译 以下为原文 Thanks greg.gates@lairdtech.com Thank you for the modified demo and platform files. I have repeated the demos. The snip.scan is working without any problem. However, I can build and download the demo.syterling.demo. when it runs, it shows: ... Starting WICED vWiced_006.002.001.0002 Platform LSRSTERLING_00950 initialised Started ThreadX v5.8 Initialising NetX v5.10_sp3 Creating Packet pools WLAN MAC Address : 00:25:CA:09:B5:3D WLAN Firmware : wl0: Apr 30 2018 04:14:19 version 7.45.98.50 (r688715 CY) FWI D 01-283fcdb9 WLAN CLM : API: 12.2 Data: 9.10.39 Compiler: 1.29.4 ClmImport: 1.36.3 Cr eation: 2018-04-11 22:31:21 Application DCT hostname : sterling.tiwiconnect.com apiEndpoint : /lift tcpPort : 80 securePort : 443 transport : HTTP clientId : apiKey : userKey : secretKey: Device Info deviceName : Sterling WICED Carrier Board deviceTypeName : lrd_sterlingEvb_demoKit_0_1_0 deviceTypeVer : 0.1.0 xfrmName : lrd_sterlingEvb_elv_0_1_0 xfrmVer : 0.1.0 firmwareName : lrd_sterlingEvb_simpleDemo_1_0_0 firmwareVer : 1.0.0 Expected SPI chip ID:d5 Detected: d4 00:00:02.834000 GKI_exception(): Task State Table 00:00:02.839000 GKI_exception 65524 Unable to allocate buffer pools 00:00:02.845000 GKI_create_task func=0x803cdbd id=1 name=BTU stack=0x0 stack Size=4096 00:00:02.853000 GKI_create_task thread_id failed(8), BTU! 00:00:02.858000 GKI_create_task func=0x803e585 id=0 name=HCISU stack=0x0 sta ckSize=3072 00:00:02.867000 GKI_create_task thread_id failed(8), HCISU! **** Waiting, No WiFi Network Configuration **** Because of the issues, I didn't see the BLE being turned on. Regards Jieqiu |
Jieqiu 我刚刚意识到我给你的是错误的演示,我道歉。 Laird将工作,以提供演示在英镑LWB WORD扩展板产品网页完全功能与新版本的WICE。对于现在的WRESD版本4,X需要在Debug /LWB上正确编译和实现。 最好的问候, 盖茨-莱尔德/LSR 以上来自于百度翻译 以下为原文 Jieqiu, I just realized I sent you the wrong demo, my apologies. Laird will be working to get the demo provided on the Sterling-LWB WICED Expansion Board product web page fully functional with newer versions of WICED. For now WICED version 4.x is needed to correctly compile and implement on the Discovery/LWB. Best Regards, G. Gates - Laird/LSR |
你好,G.GATES@ 我用你的建立提供下载SDK开发更新。它内置和下载没有任何问题。 手机应用程序的通信装置通过可控制发光二极管。然而,当我试图将设备连接到远程服务器,它失败了。似乎它已经加入了无线网络并没有登记到服务器。 … … ***等待,没有WiFi网络配置*** Wi-Fi配置保存… 名称:equivital 安全模式:WPA2混合 保存WiFi配置 WiFixCONFIG:连接Wi-Fi… 加入:equivital 成功连接:等生的 通过DHCP获取IPv4地址 DHCP客户端主机名WICED IP IPv4网络就绪IP:192.16834.123 WiFiFigFig:Wi-Fi连接… free_heap_space:20224 加速:256 256 17088 问:617 - 331 - 397 陀螺:145 68 14 数据发送 未找到密钥 没有在HTTP报头中找到X-LIFT操作 HTTP请求: 后/电梯/ RPC的HTTP / 1.1 主持人:英镑。tiwiconnect .com:80 x-lift-apikey: x-lift-xfrm:lrd_sterlingevb_elv_0_1_0 x-lift-xfrm-ver:0.1.0 内容类型:application/json;字符集= UTF-8 内容长度:612 … … 在移动应用程序,它显示“错误与服务器通信:禁止” 当做 结仇 以上来自于百度翻译 以下为原文 Hi greg.gates@lairdtech.com I have used the update you provided to build and download on SDK 6.0. It built and downloaded without any problem. The mobile app can communicate to the device through BLE and control the LEDs. However, when i tried to connect the device to the remote server, it failed. It seems that it has joined the wireless network and failed to register onto the server. ... ... **** Waiting, No WiFi Network Configuration **** Saving Wi-Fi configuration... SSID: Equivital Security Mode: WPA2 Mixed Saved WiFi Configuration WIFI_CONFIG: Connecting Wi-Fi... Joining : Equivital Successfully joined : Equivital Obtaining IPv4 address via DHCP DHCP CLIENT hostname WICED IP IPv4 network ready IP: 192.168.34.123 WIFI_CONFIG: Wi-Fi Connected... free_heap_space: 20224 accel: 256 256 17088 mag: 617 -331 -397 gyro: -145 68 14 data send key not found Did not find x-lift-actionPend in http header HTTP Request: POST /lift/rpc HTTP/1.1 Host: sterling.tiwiconnect.com:80 x-lift-apikey: x-lift-xfrm: lrd_sterlingEvb_elv_0_1_0 x-lift-xfrm-ver: 0.1.0 Content-Type: application/json; charset=utf-8 Content-Length: 612 ... ... On the mobile app, it shows "Error communicating with the server: Forbidden" Regards Jieqiu |
Jieqiu 我发给你的代码是一个不同的演示。你可以用它来帮助修改的新版本的WICED兼容WICED演示。服务器通信将不允许用于您的设备。 最好的问候, LAILD/LSR 以上来自于百度翻译 以下为原文 Jieqiu, The code that I sent you was for a different demo. You can use it to help modify the WICED demo for compatibility to the newer version of WICED. Server communication will not be allowed for your device. Best Regards, Laird/LSR |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1865 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1545 浏览 1 评论
605浏览 2评论
450浏览 2评论
448浏览 2评论
400浏览 2评论
1081浏览 2评论
GMT+8, 2025-1-11 10:32 , Processed in 0.698208 second(s), Total 51, Slave 46 queries .
