使用的是CCS3.3,在F2812的内部RAM中打断点调试程序时,发现这条语句(Freq_U_I >60.0)不满足的情况下,还会停在下面的语句Stop_flag = 1处, 但是,接着运行时,Stop_flag的实际值却没有随之变化,即不是等于1,这是怎回事? 有哪位高手了解情况的?告知小弟。。。感激不尽 |
7 个讨论
见附件堆栈溢出监测的文档说明和相关例程。 Customer can follow below step to enable this function: Step1. Customer need to modify the RAM based on their .cmd file. RAM is the RAM section which customer used for stack. SECTIONS [ .stack: RUN = RAM, RUN_START(_HWI_STKBOTTOM), RUN_END(_HWI_STKTOP), PAGE = 1 ] Step2: Add below S/W in before the main loop extern unsigned int HWI_STKBOTTOM; extern unsigned int HWI_STKTOP; #define margin 45 error = STKOV_initSystemStack((unsigned long)&HWI_STKBOTTOM, (unsigned long)&HWI_STKTOP, margin); Step3: Add “stkov_systemstack.c” and “stkov.h” to their project. - ERIC |
64 浏览 1 评论
1002 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
649 浏览 2 评论
240浏览 29评论
1207浏览 23评论
349浏览 20评论
323浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 01:46 , Processed in 1.069193 second(s), Total 69, Slave 58 queries .
