我的电压调节器失灵了,是我的错。未观察到最大电压(3.3V)。被喂养超过6伏特。当它失败时,它将输出电压完全输出出去。它喂养一个16F1823,它的绝对最大电压为6.5伏特。改变了稳压器并编程了16F1823。我的问题是,如果有人给这个芯片的+引脚提供一个不受控制的(因为我认为这是从稳压器中出来的PIC)6.5伏特和PIC是半导体,这会损坏PIC吗?PIC似乎运行良好,但我担心它可能会失败后,许多电源UPS,我应该改变它。-基思
以上来自于百度翻译 以下为原文 Had a voltage regulator fail on me; my fault. Didn't observe maximum voltage in (3.3V reg. Was being fed a little more than 6 volts). When it failed it sent the full inout voltage out the 'out' pin. It was feeding a 16F1823 which has an absolute max voltage of 6.5 volts. Changed up the regulator and programmed the 16F1823. My question is, if someone fed the + pin of this chip an unregulated (because I think that's what was coming out of the regulator into the PIC) 6.5 volts and being that the PIC is a semiconductor, would this damage the PIC? The PIC seems to be working fine but I'm worried that it might fail after numerous power ups and should I change it.-Keith |
通常PICS非常健壮,所以在你的情况下,我会说绝对没有烦恼!让他们用24V烧毁。在9V左右快速扣球,没有问题…
以上来自于百度翻译 以下为原文 Usually PICs are quite robust, so in your case I'd say definitely no worries! Got them burned with 24V. With a quick spike at 9V or so, no problem... |
5362 浏览 9 评论
2093 浏览 8 评论
1992 浏览 10 评论
3274 浏览 3 评论
2305 浏览 5 评论
870浏览 1评论
756浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-24 07:30 , Processed in 1.174151 second(s), Total 78, Slave 63 queries .
