扫一扫,分享给好友
我发送0x05或0x35没有走出寺。我把CS低之前,SCK的功能,和当数据完成CS变高。我把一切都搞糟了。
以上来自于百度翻译 以下为原文 I am sending 0x05 or 0x35 and nothing goes out of SI. I put CS low before, the sck is functioning, and the when the data finished CS goes high. I tryed everything. |
8个回答
您好,AVPPOIAN353580241,
的s25fl164k配置是什么模式?SPI?Dual?还是四元? 如果s25fl164k配置成SPI模式,Si(pin-5)是输入信号引脚只有(SI =串行);将数据读取等。 如果s25fl164k配置双模式,Si(pin-5)现在变成我/ o-0;数据可以从我o-0读我/ 1双模式。 如果s25fl164k配置在四模式,Si(pin-5)现在变成我/ o-0;数据可以从我o-0读,我/我/ O-1,O-2和我/ O-3 在四模式。 请确认所s25fl164k配置模式。 谢谢你,诚挚的问候, 艾伯特 赛普拉斯应用支持 以上来自于百度翻译 以下为原文 Hello Avppoian_3580241, What mode is the S25FL164K configured in? SPI?, Dual? or Quad? If the S25FL164K is configured in SPI mode, SI (pin-5) is an input signal pin only (SI = Serial-In); data will be read from SO. If the S25FL164K is configured in Dual mode, SI (pin-5) now becomes I/O-0; data can be read from I/O-0 and I/O-1 in Dual mode. If the S25FL164K is configured in Quad mode, SI (pin-5) now becomes I/O-0; data can be read from I/O-0, I/O-1, I/O-2 and I/O-3 in Quad mode. Please verify and confirm as to which mode the S25FL164K is configured in. Thank you and best regards, Albert Cypress Applications Support |
cmh21 发表于 2018-8-24 16:28 的s25fl164k配置在SPI模式下,Si(pin-5)是输入信号引脚 只有(四=串行);将数据读取等。这是你的方式 告诉我。SPI是单一模式,第一。 2018-07-17 17:55 gmt-03:00 ASBR <;社区经理@柏。COM & gt;: <;HTTP:/ / www.cypress .com & gt; 赛普拉斯开发者社区 <;https://community.cypress.com/?ET =手表。电子邮件。螺纹& gt; 我试图sl25164k但没有出去四阅读的东西 第5脚? 回复ASBR <;https://community.cypress.com/people/a***r?ET =手表。电子邮件。螺纹>;*也不 闪光-查看完整的讨论 <;https://community.cypress.com/message/163076?ET =手表。电子邮件。螺纹# 163076 & gt; 以上来自于百度翻译 以下为原文 The S25FL164K is configured in SPI mode, SI (pin-5) is an input signal pin only (SI = Serial-In); data will be read from SO. This is in way that you told me. The SPI is in single mode, the first. 2018-07-17 17:55 GMT-03:00 a***r <community-manager@cypress.com>: <http://www.cypress.com> |
cmh21 发表于 2018-8-24 16:28 我开始读ID命令0x9f但我比如写数据 0xAA和读取,没有发生,有些事情是错误的。我读过 数据表,但不太清楚。我打开写使能,然后擦掉一块 64K,的我写地址0x00 0x00 0x00数据0xaa然后我读 0xFF或什么也不来。代码示例存在一个问题。这是 附上我的代码。 2018-07-18 8:13 gmt-03:00亚历山大Voigt大波扬<;avppoian @ Gmail。COM & gt;: 的s25fl164k配置在SPI模式下,Si(pin-5)是输入信号引脚 只有(SI =串行in);数据将从SO读取。这是这样的 你告诉过我的。SPI为单模,第一种。 gt; 2018-07-17 17:55 gmt-03:00 ASBR <;社区经理@柏。COM & gt;: & http://wwwycop.com & gt; 柏树开发者社区 >;>;<;https://community.cypress.com/?ET=手表,电子邮件,线程& GT; >;>;我试图sl25164k但没有出去四阅读的东西 5针? >;>; >;>;回复ASBR >;>;<;https://community.cypress.com/people/a***r?ET =手表。电子邮件。螺纹>;*也不 >;>;闪光-查看完整的讨论 >;>;<;https://community.cypress.com/message/163076?ET =手表。电子邮件。螺纹# 163076 & gt; >;>; (3)spi_pooling_rev00 .zip 5.1 MB 以上来自于百度翻译 以下为原文 I am getting to read ID with command 0x9F but I write a data for example 0xAA and read and nothing happen, something is wrong. I have read the datasheets but not so clear. I tun on write enable, then i erase a block of 64K, the i write the data 0xAA on adress 0x00 0x00 0x00 and then I read and come 0xFF or nothing. There is a problem with the codes examples. This is my code attached. 2018-07-18 8:13 GMT-03:00 Alexandre Voigt da Poian <avppoian@gmail.com>: The S25FL164K is configured in SPI mode, SI (pin-5) is an input signal pin> 2018-07-17 17:55 GMT-03:00 a***r <community-manager@cypress.com>:>> <http://www.cypress.com> >> Cypress Developer Community >> <https://community.cypress.com/?et=watches.email.thread> >> I am trying to reading something of SL25164K but nothing goes out to SI >> pin 5? >> >> reply from a***r >> <https://community.cypress.com/people/a***r?et=watches.email.thread> in *Nor >> Flash* - View the full discussion >> <https://community.cypress.com/message/163076?et=watches.email.thread#163076> >>
你好avppoian_3580241, 请附上串行低电平驱动器(SLLD)关于串行NOR闪存产品。 请使用SLLD为S25FL164K 希望这有助于… 诚挚的问候, 艾伯特 spansion_slld_13.2.1.exe.zip 6.6 MB 以上来自于百度翻译 以下为原文 Hello Avppoian_3580241, Please find attached the Serial Low level Drivers (SLLD) in regards to Serial NOR FLASH memory products. Please use this SLLD for the S25FL164K Hope this helps... Best regards, Albert
解释得不好,我想做,但什么也没发生。
******扇区1×4千字节** CSYOFF; 删除(); EsCREVEN-NOR(0x06/1); 删除(); Cson on; 删除(); CSYOFF; 删除(); MaSTTXDATA〔1〕=0x00; MaSTTXDATA〔2〕=0x00; MaSTTXDATA〔3〕=0x00; MaSTTXDATA〔4〕=0x00; EXCREVEN-NOR(0x20.4); 勒诺(1); 删除(); Cson on; CSYOFF; 删除(); EXCREVEN-NOR(0x04/1); 删除(); Cson on; 删除(); (三) 我第一次写escreve_nor(0x20,4);当我读到的数据显示0xff。然后我改变了我的行命令escreve_nor(0x20,5);我编写和发送程序,将数据写入我可以正确读取。身份登记是阅读0x00,地位也阅读0x03登记。 以上来自于百度翻译 以下为原文 Not explain well, I tryed to do but nothing happens. /*** ERASE SECTOR 1 4 KBYTES ***/ CS_OFF; Delay(); Escreve_NOR(0x06,1); Delay(); CS_ON; Delay(); CS_OFF; Delay(); masterTxData[1] = 0x00; masterTxData[2] = 0x00; masterTxData[3] = 0x00; masterTxData[4] = 0x00; Escreve_NOR(0x20,4); Le_NOR(1); Delay(); CS_ON; CS_OFF; Delay(); Escreve_NOR(0x04,1); Delay(); CS_ON; Delay(); /**************************************************************************/ First I write Escreve_NOR(0x20,4); and when I read the data shows 0xFF. Then I changed my line command to Escreve_NOR(0x20,5); and I compile and send the program and then the data are write and I can read correctly. The status register is reading 0x00, the status register too is reading 0x03. |
你好,AVPPOIAN353580241 我不明白你的说法: “我先写escreve_nor(0x20,4);当我读到的数据显示0xff。然后我把我的行命令改为EXCREVER NOR(0x20,5); 我编写和发送程序,将数据写入我可以正确读取。身份登记是阅读0x00,地位也0x03登记阅读。” 命令20h是扇区擦除 0xFFH是擦除状态。 “身份登记是阅读0x00,地位也0x03登记阅读。” 1)。如果只有一个身份登记,什么是状态登记实际阅读,0x00h或0x03h? 2)。哪一个状态寄存器正在读取0x00? 3)。哪一个状态寄存器正在读取0x03H? 请在最方便的时候澄清… 最好的问候, 艾伯特 柏树应用支持 以上来自于百度翻译 以下为原文 Hello Avppoian_3580241 I do not understand your statement : " First I write Escreve_NOR(0x20,4); and when I read the data shows 0xFF. Then I changed my line command to Escreve_NOR(0x20,5); and I compile and send the program and then the data are write and I can read correctly. The status register is reading 0x00, the status register too is reading 0x03. " - Command 20h is Sector Erase - 0xFFh is the Erased state. " The status register is reading 0x00, the status register too is reading 0x03. " 1). If only one status register, what is the status register actually reading, 0x00h or 0x03h? 2). Which status register is reading 0x00h? 3). Which status register is reading 0x03h? Please clarify at your earliest convenience... Best regards, Albert Cypress Applications Support |
cmh21 发表于 2018-8-24 17:19 我明白了,我不是在擦除状态寄存器之后才正确阅读的。 命令,现在可以了。 2018-07313:48 GMT-03:ASBR & LT;社区经理@ CyPress .com & Gt; & http://www. Copress。com & gt; 柏树开发者社区 HTTPS://Cullist.CyPress?COM/?ET=手表,电子邮件,线程& GT; 我想读一些SL25164K的东西,但是没有任何东西能进入SI。 引脚5? ASBR回复 HTTPS://Cullist.CyPl.com /PoePs/ASBR?ET=手表,电子邮件。 FLASH * -查看完整的讨论 HTTPS://Cullist.CyPl.com/Mease/164621?ET =手表。电子邮件。螺纹# 164621 & gt; 以上来自于百度翻译 以下为原文 I got it, I wasn´t reading the status register correctly after erase command and now is ok. 2018-07-31 13:48 GMT-03:00 a***r <community-manager@cypress.com>: <http://www.cypress.com> |
dingxueli 发表于 2018-8-24 17:30 好的,谢谢,很高兴知道… 最好的问候, 艾伯特 赛普拉斯应用支持 以上来自于百度翻译 以下为原文 Okay, thank you, that is good to know... Best regards, Albert Cypress Applications Support |
754个成员聚集在这个小组
加入小组2113 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1793 浏览 6 评论
1540 浏览 1 评论
580浏览 2评论
432浏览 2评论
444浏览 2评论
391浏览 2评论
993浏览 2评论
GMT+8, 2024-12-30 01:39 , Processed in 0.874449 second(s), Total 60, Slave 54 queries .
