扫一扫,分享给好友
你好,
我收到了HX3PD EVE板。当我把它连接到我的电脑时,我遇到了两个问题: 1。PC找不到芯片的驱动程序,只显示它是C型桥。我在哪里可以找到司机? 2。我被告知EZ-PD配置实用程序可以用来配置HX3PD芯片。然而,下载的最新版本并不支持它。我如何配置这个芯片? 谢谢。 以上来自于百度翻译 以下为原文 Hi, I received an HX3PD eval board. When I connected it to my PC, I encountered two issues: 1. The PC could not find a driver for the chip and only shows it's a type-C bridge. Where can I find the driver? 2. I was told the EZ-PD configuration utility could be used to configure the HX3PD chip. However, the latest version downloaded doesn't support it (yet). How can I configure this chip? Thanks. |
3个回答
嗨,赵念,
您需要从网站下载HX3PD配置实用工具。该实用程序仍在开发中,因此目前只有完整的固件更新选项可用。如果您想要一个特定的配置,CyPress可以为您提供所需的预先配置的固件映像,您可以下载到该板上。该实用工具的完整版本将很快发布,之后将启用配置选项。 你可以指定你的连接枢纽,你的电脑吗? 当做, 拉贾斯 以上来自于百度翻译 以下为原文 Hi Zhaonian,[size=1.2em] You will need to download the HX3PD Configuration Utility from the website. The utility is still under development, hence only complete firmware update option is available as of now. If you want a specific configuration as such, Cypress can provide you the required pre-configured firmware image which you can download onto the board. Full version of the utility will be released soon, after which configuration option will be enabled. Can you specify how you are connecting the hub to your PC? Regards, Rajath |
zhanan5193 发表于 2018-8-24 17:46 嗨,Rajath, 谢谢你的回复!我能找到的配置实用程序在线。然而,这hx3pd仍然显示了我的Windows PC没有任何驱动程序,连接上下游港口设备不能正常运行。你能帮司机的问题? 谢谢, 肇年 以上来自于百度翻译 以下为原文 Hi Rajath, thanks for your reply! I was able to find the config utility online. However, the HX3PD still shows up on my windows PC without any driver, and peripherals connected on its downstream ports are not functioning properly. Could you help with the driver issue? Thanks, Zhaonian |
qian801228 发表于 2018-8-24 17:56 嗨,赵念, 如果枚举为C型桥,则应该工作。你可以请详细说明究竟是在DS端口的问题? 当做, 拉贾斯 以上来自于百度翻译 以下为原文 Hi Zhaonian, If its enumerating as Type-C bridge, it should work. Can you please elaborate what exactly is the issue on the DS ports? Regards, Rajath |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
509浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-2 13:29 , Processed in 0.694517 second(s), Total 49, Slave 43 queries .
