嗨,大家好,
是否有人为CYW4345 5创建了ORCAD部件库和/或推荐使用2G/5G/BT SoC的参考设计? 谢谢 以上来自于百度翻译 以下为原文 Hi all, Does anyone have the orCad part library created for the CYW43455 and/or a recommended reference design for using the 2g/5g/bt SoC ? Thanks |
7个回答
我看着我们的问候的cyw943455evb_02广阔的市场推出。
接下来要做的更多。 SGUP 以上来自于百度翻译 以下为原文 I am looking into where we are with regards to the broad market launch of the CYW943455EVB_02. More to follow. sgup |
嗨,杰森,
你是在找cyw43455 OrCAD象征硅或模块?我们不推荐使用板上芯片设计的Wi-Fi /组合器件复杂性得到最佳的性能和设计的东西,通过认证。如果你正在寻找符号的模块,我建议可以与基于模块所使用的模块供应商联系。如果你没有选择一个模块,请在物联网解决方案指南模块的选择指南。 让我们知道这是否解决了你的问题。 谢谢 萨钦 以上来自于百度翻译 以下为原文 Hi Jason, Are you looking for orcad symbol for CYW43455 silicon or module? We do not recommend chip-on-board designs using Wi-Fi / combo devices due complexity involved to get best performance and design something that passes certifications. If you are looking for symbol for module, I would recommend to get in touch with the module vendor based on the module that you are using. If you have not selected a module yet, please refer to module the selector guide at IoT Solutions Guide. Let us know if that addresses your question. Thanks Sachin |
的cyw943455evb_02 EVK将在下一个版本的SDK一起发布(V7.0)。我们通常提供的原理图,Gerber,BOM和布局每个EVK释放文件。 该EVK将利用村田1mW,它是一种基于43455认证模块。作为sgup提到,芯片下联合国认证的设计通常不支持在广阔的市场的复杂性。 以上来自于百度翻译 以下为原文 The CYW943455EVB_02 EVK will be released in conjunction with the next version of the SDK (v7.0). We normally provide schematic, gerber, BOM and layout files with each EVK release. The EVK will leverage the Murata 1MW, which is a certified module based on the 43455. As sgup alluded to, chip down un-certified designs are typically not supported within the broad market due to complexity. |
jnsahdjhsdu 发表于 2018-8-23 15:14 谢谢。我们的应用程序需要一个外部天线,可悲的是,大多数模块的使用规则。我会联系当地的销售团队。谢谢 以上来自于百度翻译 以下为原文 Thanks. Our applications requires the use of an external antenna which sadly rules out most modules. I will contact the local sales team. Thanks |
wonick 发表于 2018-8-23 15:30 谢谢-也将与村田联系。 以上来自于百度翻译 以下为原文 Thanks - will contact Murata also. |
贾森迪安哈特353548 Laird有英镑LWB5支持。AC和外部天线选项,预认证(CYW43353为基础)。 sterling-lwb5 Wi-Fi和蓝牙模块| lairdtech 双频802.11ac Wi-Fi +蓝牙版模块 这种完全认证的解决方案支持IEEE 802.11a/b/g/n/ac WLAN、BT 2.1 + EDR和BLE 4.2无线连接,并且对于使用Linux或基于Android的微处理器的产品是理想的。3模块选项,工业额定温度(-40至+85°°C),和一个行业领先的广度的认证和天线选择的sterling-lwb5给开发商满足他们的设计要求,具有显著的灵活性。 在5GHz bandthree配置选项提供高速数据应用802.11ac:SIP模块(10mm×10mm×1.6mm)芯片天线模块(21毫米x 15.5毫米x 3毫米)与外部的美国佛罗里达州的天线端口模块(21毫米x 15.5毫米x 3毫米)天线和美国佛罗里达州模块版本都足迹Sterling LWB(cyw4343w和引脚兼容的基础) 以上来自于百度翻译 以下为原文 jasondeanhart_3538486 Laird has the Sterling LWB5 which supports .ac and external antenna options, pre-certified (CYW43353 based). Sterling-LWB5 Wi-Fi plus Bluetooth Module | LairdTech Dual-Band 802.11ac Wi-Fi + Bluetooth v4.2 Module This fully certified solution supports IEEE 802.11a/b/g/n/ac WLAN, BT 2.1+EDR, and BLE 4.2 wireless connectivity and is ideal for products utilizing either a Linux or Android-based microprocessor. With three module options, an industrial temperature rating (-40° to +85° C), and an industry-leading breadth of certifications and antenna options, the Sterling-LWB5 gives developers significant flexibility in meeting their design requirements.
wonick 发表于 2018-8-23 16:03 谢谢你。看起来这个模块大约是25美元,不幸的是它让我们的项目遥不可及。 以上来自于百度翻译 以下为原文 Thanks for this. Looks like the module is about $25 which unfortunately puts it out of reach for our project. |
759个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1137浏览 2评论
GMT+8, 2025-2-23 05:45 , Processed in 0.787578 second(s), Total 55, Slave 50 queries .
