IQVIEW Benefits IQView|Litepoint|WIFI|无线网络综合测试仪|WIFI测试仪 The LitePoint IQview® 802.11a/b/g/n WLAN R&D Test Solution is a popular test instrument for RF testing of 802.11a/b/g WLAN products, including MIMO and optional Bluetooth + EDR. Network interface cards, access points and embedded components are typically tested using this product. Features -- Seamless analysis of DSSS (802.11b/g) and OFDM (802.11a/g) WLAN signals -- Advanced VSA and VSG combined with the capabilities of a power meter and spectrum analyzer in a single instrument -- Operation in both 2.4 GHz and 5 GHz bands -- Baseband I/O facilitates product debugging with LitePoint IQdebug™ Monitor and Control Tool -- High-performance VSA * Wide bandwidth (±33 MHz) * Capture-once-measure-all operation * High phase linearity, low phase noise, low noise figure * Graphical and numerical display of measurement results -- High-performance VSG * Low noise figure * Pre-defined 802.11a/b/g transmit test signals * Impairments can be introduced in real- time to the transmit test signal * Generation of arbitrary 802.11a/b/g waveforms simplified by optional IQwave WLAN Waveform Generator Software -- Simple control interfaces * IQsignal Signal Analysis Software Suite facilitates signal analysis, signal generation, and debugging * LitePoint API (IQapi™) supports Visual C/C++ test scripts for use in manufacturing -- Faster test time * Test time reduced by from minutes per device to seconds compared to separate instruments for VSA, spectrum analyzer and power meter * Independent simultaneous Rx and Tx measurements * Support for dual-head test functionality -- Faster time to production * Intuitive user interface means no learning curve * No complicated test set-up or calibration; tests are pre-configured * Easy to re-configure manufacturing stations to test different chipsets * Consistent test results across R&D and manufacturing for quick identification and fix of problems -- Consistent quality and performance assured * Direct measurement of transmitter performance using EVM and other signal quality metrics * Efficient and repeatable measurements * Ability to capture, analyze and debug raw signal data0n any PC -- Capital investment protected * One-box tester solution eliminates need for multiple test products * No other equipment or software required * Software upgrades ensure compliance with standards changes System Requirements -- PC: Intel® Pentium® Processor or compatible -- Operating system: Microsoft Windows 2000; Windows XP Professional; Windows XP Home Edition -- Memory: 128MB of RAM -- Disk space: 200MB of available hard disk space -- Monitor: 1024 x 768 resolution -- Connectivity: TCP/IP over 10/100BaseT Ethernet |
1862 浏览 1 评论
摩尔斯微电子推出社区论坛与开源GitHub资源库,新资源的上线将加速全球工程师与开发者的Wi-Fi开发进程
1381 浏览 0 评论
8947 浏览 1 评论
9521 浏览 0 评论
32444 浏览 3 评论
GMT+8, 2024-11-10 15:58 , Processed in 0.319446 second(s), Total 32, Slave 27 queries .
