扫一扫,分享给好友
你好,
使用PSoC3启动另一个项目(用过成功)而不可得的样机运行。 我搬到我的cy8ckit-001 + cy8ckit-009检查firmaware /程序员,我得到“设备是公认的PSoC creator却不支持使用它在这个时候”,或“HEX文件不与获得装置”(最新miniprog PSoC程序员比赛3)。我想这是因为我的009板2变种芯片。我是正确的,是唯一的出路来减少芯片和替换它吗? 没有任何造物主的版本回到3仍然支持009板吗? 干杯 戴夫 以上来自于百度翻译 以下为原文 Hi, Starting another project using PSoC3 (used it before successfully) but can't get the prototype to run. I moved to my CY8CKIT-001+CY8CKIT-009 to check the firmaware/programmer and I get "Device was recognized but PSoC creator does not support using it at this time", Or "hex file does not match with the aquired device" from PSOC Programmer (latest miniprog 3) . I assume this is because the chip on my -009 board is the ES2 variant. Am I correct and is the only way out to cut the chip off and replace it? Did any of the Creator versions back to 3.0 still support the -009 board? Cheers Dave |
你需要更换PSoC3 ES2芯片使用它最新的miniprog3和创造者
你可以把这个文件从ES2版本所做的更改: HTTP://www. CyPress .COM/FIL/10881/下载 以上来自于百度翻译 以下为原文 You need to replace the PSoC3 ES2 chip for using it with latest MiniProg3 and Creator You can refer this doc for the changes done from ES2 version : http://www.cypress.com/file/108581/download |
759个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1137浏览 2评论
GMT+8, 2025-2-23 05:03 , Processed in 0.748013 second(s), Total 42, Slave 37 queries .
