在CyByLyGAPRelvVIGIN DEVICESIOFIFT结构中,有对等标识设备地址。系统只需要用对等IRK解决对等解析地址。身份设备地址使用什么?
以上来自于百度翻译 以下为原文 In the CYBLE_GAP_RESOLVING_DEVICE_INFO_T structure, there is the peer identity device address. The system need only resolve the peer resolving address with peer IRK. What is the identity device address use? |
你好,德里克,
你知道解决私有地址(RPA)可以定期更换,可以解决使用隐私功能的设备。 每个启用隐私的BLE设备有一个唯一的地址,称为身份证地址。身份地址的BLE设备的公共地址或静态地址。每个启用隐私的BLE设备还具有一个身份解决关键(IRK)。它是由稳定的装置用来产生它的RPA和通过对等设备用于解决BLE设备的RPA。双方的身份地址和它交换的配对过程的第三个阶段。启用隐私的BLE设备维护一个列表,包括对等设备的身份地址,当地折磨的BLE设备用于生成RPA,和对等设备的使用解决对等设备的RPA。这就是所谓的列表的解决。 请参阅第7部分。链路层(LL)对隐私更详细的隐私。 谢谢, 心理医生。 以上来自于百度翻译 以下为原文 Hello Derek, You know that Resolvable Private Addresses (RPA) can be changed at regular intervals, can be resolved and are used by Privacy enabled devices. Every Privacy-enabled BLE device has a unique address called the Identity Address. The Identity Address is the Public Address or Static Address of the BLE device. Every Privacy-enabled BLE device also has an Identity Resolving Key (IRK). The IRK is used by the BLE device to generate its RPA and is used by peer devices to resolve the RPA of the BLE device. Both the Identity Address and the IRK are exchanged during the third stage of the pairing process. Privacy-enabled BLE devices maintain a list that consists of the peer device’s Identity Address, the local IRK used by the BLE device to generate its RPA, and the peer device’s IRK used to resolve the peer device’s RPA. This is called the Resolving List. Please refer the section 7. Link Layer (LL) Privacy for more details on Privacy. Thanks, PSYU. |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1260浏览 2评论
GMT+8, 2025-3-6 18:53 , Processed in 0.739573 second(s), Total 43, Slave 38 queries .
