大家好,
我正在使用UDB I2C主组件与PSoC 5LP CY8CKIT-059一起工作。我没有问题写I2C设备,我想与使用Uti8I2C*MaultRead Bufff通信,但在读完I2C组件的数据表之后,我无法理解如何从从属的子地址读取。 i2c_masterreadbuf的卡片(卡片slaveaddress,uint8 * rddata,uint8 CNT,uint8模式)似乎是功能我会用,但我可以从文件告诉,这只会读“碳纳米管”的字节从I2C Slave的基地址数。我能从子地址读吗?再次,我已经阅读数据表和我没有办法得到答案的形式。 谢谢! 布瑞恩·科格兰 以上来自于百度翻译 以下为原文 Hello all, I am working with the PSoC 5LP Cy8CKIT-059 using a UDB I2C master component. I have no trouble writing to the I2C device I want to communicate with using uint8 I2C_MasterReadBuf, but after reading through the datasheet for the I2C component, I cannot figure out how to read from a sub-address of the slave. The uint8 I2C_MasterReadBuf(uint8 slaveAddress, uint8 * rdData, uint8 cnt, uint8 mode) seems to be the function I would use, but as far as I can tell from the documentation, this will only read "cnt" number of bytes starting from the I2C slave's base address. Is it possible for me to read from a sub-address? Again, I have read the datasheet and I have no been able to get an answer form that. Thanks! Brian Coghlan |
Brian Coghlan
我猜你用ez-i2c模块为奴隶。 第一个数据(8位或16位)后从地址是子地址。 如果你已经配置ez-i2c子地址8bit,然后从地址是子地址8位数据。 如果你已经配置ez-i2c子地址16bit,然后从地址是子地址的16bit数据。 谢谢 以上来自于百度翻译 以下为原文 Brian Coghlan, I guess you use the EZ-I2C module as the slave. The first data (8 bit or 16 bit) after slave address is sub-address. If you have configure the EZ-I2C sub-address 8bit, then the 8 bit data after the slave address is sub-address. If you have configure the EZ-I2C sub-address 16bit, then the 16 bit data after the slave address is sub-address. Thanks |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1763 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 19:49 , Processed in 0.575534 second(s), Total 43, Slave 38 queries .
