您好!
利用PSoC Creator 4.2图设计器,似乎没有一种方式连接的dietemp输出连接到一个capsense_adc输入连接,为capsense_adc组件不暴露任何连接的原理图设计。 看来capsense_adc输入只能连接到外部引脚没有内部连接。 因此,我要把dietemp输出到外部引脚,然后到capsense_adc输入引脚(可能是相同的引脚)或有一个更好的解决方案吗? 谢谢 皮特 以上来自于百度翻译 以下为原文 Hi Using PSoC Creator 4.2 schematic designer, there doesn't seem to be a way to connect the DieTemp output connection to a CapSense_ADC input connection, as the CapSense_ADC component doesn't expose any connections in the schematic designer. It looks as if the CapSense_ADC inputs can only be connected to external pins and not to internal connections. Therefore, should I connect the DieTemp output to an external pin and then to the CapSense_ADC input pin (possibly the same pin) or is there a better solution? Thanks Pete |
3个回答
你好,Pete,
DieTemp被设计成与SAR ADC一起使用。使用CAPENSESEYADC有什么特殊的原因吗? -拉吉夫 以上来自于百度翻译 以下为原文 Hello Pete, DieTemp is designed to be used with the SAR ADC. Is there any specific reason for using CapSense_ADC? -Rajiv |
嗨,拉吉夫 目的是找到最小包装的PSoC CapSense和dietemp成分可以与。 所以除使用专用ADC组件的依赖是希望去帮助实现这个目标。 在一系列的设备,但是看后,似乎如果设备没有专用ADC组件还没有dietemp组件。 谢谢你的回复 皮特 以上来自于百度翻译 以下为原文 Hi Rajiv The aim was to find the smallest packaged PSoC available with both CapSense and DieTemp components. So removing the dependency on using a dedicated ADC component was hopefully going to help achieve this goal. After look at a range of devices however, it seems that if the device doesn't have a dedicated ADC component it also doesn't have a DieTemp component. Thanks for your response Pete |
没错,Pete。DieTemp与SAR ADC。 -拉吉夫 以上来自于百度翻译 以下为原文 That is correct, Pete. DieTemp comes with the SAR ADC. -Rajiv |
757个成员聚集在这个小组
加入小组2142 浏览 1 评论
1885 浏览 1 评论
3705 浏览 1 评论
1820 浏览 6 评论
1567 浏览 1 评论
762浏览 2评论
518浏览 2评论
476浏览 2评论
434浏览 2评论
1121浏览 2评论
GMT+8, 2025-2-9 02:35 , Processed in 0.764910 second(s), Total 50, Slave 44 queries .
