目前我的广告有:
CysLyDebug MyDeFieln.AdvPARAM-GT;Advutvmin=Cylula LovithAdvIn In Min; cyble_discoverymodeinfo。advparam - >;advintvmax = cyble_slow_adv_int_max; 我可以做一包的命令无论我想要关闭广告代码,直到我想把下一个吗? 没有阈值激活? 以上来自于百度翻译 以下为原文 Currently my advertisement has : cyBle_discoveryModeInfo.advParam->advIntvMin = CYBLE_SLOW_ADV_INT_MIN; cyBle_discoveryModeInfo.advParam->advIntvMax = CYBLE_SLOW_ADV_INT_MAX; Can i advertise one packet by command wherever i want in code and close advertisement until i want to send the next one ? Without having the thresholds active? |
你好,
我们可以选择不做广告的数据包使用API”cyble_gappsetnumofadvpkts(cyble_gapp_disc_mode_info_t * advinfo,uint16 numofadvpkts)”这个函数设置广告包数量是通过空中发送开始广告。间隙周围接收cyble_evt_gapp_advertisement_start_stop事件指定号ADV包发送成功后。 启动和停止广告无论你想要下面的API可以在代码中使用: cyble_gappstartadvertisement(uint8 advertisingintervaltype)-此功能用于启动广告。 同样,cyble_gappstopadvertisement(void),这个函数可以用来退出发现模式。这个函数执行后,再也没有任何广告。 请参考数据表的组件对这些API的更多信息。 谢谢, 心理医生。 以上来自于百度翻译 以下为原文 Hello, We can advertise with selected no. of packets using the API " CyBle_GappSetNumOfAdvPkts (CYBLE_GAPP_DISC_MODE_INFO_T *advInfo, uint16 NumOfAdvPkts) " this function sets number of advertisement packets to be sent over the air and starts Advertisement. Gap Peripheral receives CYBLE_EVT_GAPP_ADVERTISEMENT_START_STOP event after specified no. of adv packets are transmitted successfully. To start and stop the advertisement wherever you want below APIs can be used in code: CyBle_GappStartAdvertisement (uint8 advertisingIntervalType) - This function is used to start the advertisement. Similarly, CyBle_GappStopAdvertisement (void ) - This function can be used to exit from discovery mode. After the execution of this function, there will no longer be any advertisements. Please refer the component datasheet for more information on these APIs. Thanks, PSYU. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 14:33 , Processed in 1.097043 second(s), Total 96, Slave 80 queries .
