你好,
我已经将PSoC项目导出到MaFaFILE。 当我第一次的出口,gen_source.mk文件结束看起来如下 Geang-LibsS- CordxM3= 当我在PSoC Creator建立项目的gen_source.mk文件获取mofidied如下 Geang-LibsS- CordxM3= 导出/ ARMGGCGUng/CyCultEngult.A 我删除了出口/ arm_gcc_generic / cycomponentlibrary,并尝试建立项目使用makefile(与改性gen_source。MK)。 我确实弄错了。 是CyComponentLibrary。使用MaFfile时需要一个文件吗? GunthOrth.JPG 167.1 K 以上来自于百度翻译 以下为原文 Hi, I have exported the PSoC project to Makefile. When I export it first time, the end of the gen_source.mk file looks as below GEN_LIBS_CortexM3= When I build the project in PSOC creator, the gen_source.mk file gets mofidied as below GEN_LIBS_CortexM3= Export/ARM_GCC_Generic/CyComponentLibrary.a I deleted the Export/ARM_GCC_Generic/CyComponentLibrary.a and tried to build the project using the makefile (with the modified gen_source.mk). I do get an error. Is CyComponentLibrary.a file required when using makefile?
gen_source.mk是PSoC Creator生成的源代码。
这个文件不能被修改。它是自动生成的PSoC Creator作为构建过程的一部分。 该文件是写在导出向导中选择的工具。之后,它将在每次构建过程的更新,基于编译设置当前工具。那就是,如果你出口Makefile和改变从GCC MDK,Makefiles中可能没有工作。的gen_source.mk文件将包含源代码,是不是在platform_debug.mk工具链支持(或platform_release。MK)。更新的平台配置文件,或使用“导出到文件”功能将文件的新工具。 CyComponentLibrary:这个库是用来合并所有的组件库在一个单一的代码库。 所以它会提供所有用于项目的组件功能。 以上来自于百度翻译 以下为原文 gen_source.mk is a PSoC Creator generated source code. This file should NOT be modified. It is automatically re-written by PSoC Creator as a part of the build process. This file is written out for the toolchain selected in the export wizard. Later, it will be updated during each Build process, based on the current toolchain in the Build Settings. That is, if you export to Makefile and change from GCC to MDK, the Makefiles will likely not work. The gen_source.mk file will contain source code that is not supported by the toolchain in platform_debug.mk (or platform_release.mk). Either update the platform configuration file, or use the "Export to Makefile" feature to regenerate the files for the new toolchain. CyComponentLibrary.a : this library is used to merge all components libraries in a single code object library. So it will provide functions for all the components used in project. |
754个成员聚集在这个小组
加入小组2105 浏览 1 评论
1851 浏览 1 评论
3669 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-23 19:04 , Processed in 0.738554 second(s), Total 46, Slave 40 queries .
