通过修改PANID和信道变量的值,然后存储到NV,下面是相关代码: if((xChanel != zgDefaultChannelList)||(xPan_ID != zgConfigPANID)) [ zgConfigPANID = xPan_ID; zgDefaultChannelList = xChanel; osal_nv_item_init(ZCD_NV_PANID, sizeof(zgConfigPANID), &zgConfigPANID); osal_nv_write(ZCD_NV_PANID, 0, sizeof( zgConfigPANID ), &zgConfigPANID); osal_nv_item_init(ZCD_NV_CHANLIST, sizeof(zgDefaultChannelList), &zgDefaultChannelList); osal_nv_write(ZCD_NV_CHANLIST, 0, sizeof( zgDefaultChannelList ), &zgDefaultChannelList); osal_start_timerEx( GenericApp_TaskID, QUBLIC_SW_RESET_EVEN ,1000); //zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE ); ] ] |
深圳雅创 发表于 2018-8-18 06:38 如果是协调器那就可以直接这么改了,不需要重新启动 // ret = NLME_NetworkFormationRequest( zgConfigPANID, zgApsUseExtendedPANID, runtimeChannel, //fsm ,屏蔽,0719 // zgDefaultStartingScanDuration, beaconOrder, //fsm ,屏蔽,0719 // superframeOrder, false ); //fsm ,屏蔽,0719 ret = NLME_NetworkFormationRequest( set_panid, zgApsUseExtendedPANID,set_channel, //fsm ,添加,0719 zgDefaultStartingScanDuration, beaconOrder, //fsm ,添加,0719 superframeOrder, false ); //fsm ,添加,0719 |
60user55 发表于 2018-8-18 06:44 您好!如果是路由节点和终端节点需要调用哪些函数?我现在直接调用osalInitTasks();多设置几次PANID或通道后会加入不了网络 |
820 浏览 1 评论
1070 浏览 0 评论
617 浏览 1 评论
466 浏览 1 评论
660 浏览 2 评论
263浏览 29评论
1224浏览 23评论
355浏览 20评论
333浏览 14评论
197浏览 13评论
GMT+8, 2025-3-5 04:47 , Processed in 0.710131 second(s), Total 72, Slave 57 queries .
