大家好,
我尝试用CAN总线协议将PSoC 3与树莓PI连接起来。我的PSoC与MCP 2551和RasBuri PI连接,与MCP 22515和2551.连接,但我仍然混淆如何沟通这些设备,谁能分享你的经验,如果你完成了这种情况?非常感谢你! 以上来自于百度翻译 以下为原文 Hello everybody, i'm attempting to connect psoc 3 with raspberry pi with can bus protocol. my psoc connected with mcp 2551 and raspberry pi is connected with mcp 22515 and 2551. but i'm still confuse about how to communicate between those devices, can anyone please share your experience if you're done with that case?. thank you so much in advance! |
你好,
你可以浏览到PSoC Creator:文件& gt;的代码示例和参考以下两个CES。 典型实例 CulyFull示例 上面的代码示例将帮助您发送和接收数据使用协议,从PSoC3。我希望这有帮助。 谢谢,Shanmathi 以上来自于百度翻译 以下为原文 Hello, You can navigate to PsoC creator: File-> Code example and refer to the following two CEs. CAN_Basic_Example CAN_Full_Example The above code examples would help you to send and receive data using CAN protocol, from PSoC3. I hope this helps. Thanks, Shanmathi |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1865 浏览 1 评论
3681 浏览 1 评论
1800 浏览 6 评论
1545 浏览 1 评论
605浏览 2评论
451浏览 2评论
448浏览 2评论
400浏览 2评论
1081浏览 2评论
GMT+8, 2025-1-11 20:18 , Processed in 0.745620 second(s), Total 41, Slave 36 queries .
