你好,我把固件移植到HTTP://wwwyCyp.com /Appulss/Houth-Apple /Field-风扇电机到M9BF121K,但是电机不能启动。
我的问题: 1。这个FW可以用在M9BF121K上吗? 2。在这个FW中,有一个名为CubSeriBuff.c的文件,你能给我一些文档来讨论这些参数吗? 三。你能给我一些建议吗? 谢谢。 以上来自于百度翻译 以下为原文 hello, I porting the firmware on http://www.cypress.com/applicati ... /inverter-fan-motor to MB9BF121K, but motor can not startup. my questions: 1. can this FW used on MB9BF121K? 2. In this FW, there is a file named Customer_Interface.c, could you give me some documents to disscuss these parameters? 3. Could you give me some other advice? thanks a lot. |
我们正在迁移的FM0 + / FM3的风扇电机解决PSoC的家庭。我们建议使用PSoC 4 S2基于倒排风扇电机控制。为此,请使用所附的PSoC Creator项目随着电机控制库。请参阅所附的直流风扇电机接口和原理图文件的更多细节。
MCU-AN-510119-E-50-DC-FANTROMOTION CUMMOTHEL接口PDF 2.1兆字节 (SCH)FANAY-MODEL -PSOC V3.PDF 122 K 风扇马达解决方案 854.7 K 以上来自于百度翻译 以下为原文 We are migrating the FM0+/FM3 based Fan Motor solution to PSoC family. We would recommend to use PSoC 4 S2 based Inverted Fan Motor Control. For this, please use attached PSoC Creator project along with motor control library. Please refer to attached DC Fan Motor Interface and schematic document for more details.
zhushanyu262 发表于 2018-8-14 07:00 FM0+/FM3不再支持吗? 我想使用新的PSoC 4来设计你的附件。 我有一些软件调试文档吗? 以上来自于百度翻译 以下为原文 Was FM0+/FM3 no longer supported? I would like use new PSoC 4 to design refer to your attachment. Are there some software debug document for me? |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1271浏览 2评论
GMT+8, 2025-3-7 04:21 , Processed in 1.062073 second(s), Total 79, Slave 63 queries .
