// //! Resets the device. //! //! This function performs a software reset of the entire device. The //! processor and all peripherals are reset and all device registers are //! returned to their default values (with the exception of the reset cause //! register, which maintains its current value but has the software reset //! bit set as well). //! //! return This function does not return. // //***************************************************************************** void SysCtlReset(void) [ // // Perform a software reset request. This request causes the device to // reset, no further code is executed. // HWREG(NVIC_APINT) = NVIC_APINT_VECTKEY | NVIC_APINT_SYSRESETREQ; // // The device should have reset, so this should never be reached. Just in // case, loop forever. // while(1) [ ] ] |
820 浏览 1 评论
1070 浏览 0 评论
617 浏览 1 评论
466 浏览 1 评论
660 浏览 2 评论
263浏览 29评论
1224浏览 23评论
355浏览 20评论
333浏览 14评论
197浏览 13评论
GMT+8, 2025-3-5 07:12 , Processed in 0.724959 second(s), Total 42, Slave 37 queries .
