interrupt.c中 void IntRegister(uint32_t ui32Interrupt, void (*pfnHandler)(void)) [ uint32_t ui32Idx, ui32Value; // // Check the arguments. // ASSERT(ui32Interrupt < NUM_INTERRUPTS); // // Make sure that the RAM vector table is correctly aligned. // ASSERT(((uint32_t)g_pfnRAMVectors & 0x000003ff) == 0); // // See if the RAM vector table has been initialized. // if(HWREG(NVIC_VTABLE) != (uint32_t)g_pfnRAMVectors) [ // // Copy the vector table from the beginning of FLASH to the RAM vector // table. // ui32Value = HWREG(NVIC_VTABLE); for(ui32Idx = 0; ui32Idx < NUM_INTERRUPTS; ui32Idx++) [ g_pfnRAMVectors[ui32Idx] = (void (*)(void))HWREG((ui32Idx * 4) + ui32Value); ] // // Point the NVIC at the RAM vector table. // HWREG(NVIC_VTABLE) = (uint32_t)g_pfnRAMVectors; ] // // Save the interrupt handler. // g_pfnRAMVectors[ui32Interrupt] = pfnHandler; ] |
851 浏览 1 评论
1082 浏览 0 评论
626 浏览 1 评论
477 浏览 1 评论
668 浏览 2 评论
270浏览 29评论
1232浏览 23评论
365浏览 20评论
345浏览 14评论
217浏览 13评论
GMT+8, 2025-3-10 10:03 , Processed in 1.103053 second(s), Total 71, Slave 59 queries .
