ADISIMPE是基于SPICE MODEL进行电路仿真的工具。ADL5535没有SPICE MODEL,一般ADI的器件如果有SPICE MODEL,会在产品页有显示,可以进行下载。
“ADIsimRF is an easy-to-use RF signal chain calculator. Cascaded Gain, Noise Figure, IP3 and P1dB as well as total power consumption are calculated.” “The ADIsimPLL design tool is a comprehensive and easy-to-use PLL synthesizer design and simulation tool. All key non-linear effects that can impact PLL performance can be simulated, including phase noise, Fractional-N spurs, and anti-backlash pulse.” ADISIMRF和ADISIMPLL是定制化的仿真软件,只争对RF器件和PLL器件进行仿真。 |
2296个成员聚集在这个小组
加入小组1072 浏览 2 评论
1441 浏览 2 评论
1982 浏览 1 评论
4307 浏览 2 评论
9110 浏览 1 评论
1725浏览 3评论
1730浏览 2评论
1072浏览 2评论
1733浏览 2评论
1441浏览 2评论
GMT+8, 2025-1-31 18:46 , Processed in 0.569845 second(s), Total 45, Slave 40 queries .
