Hi team,
I am use AD7606 at the platform IMX6, according to the instruction of AD7606 IIO Multi-Channel Simultaneous Sampling ADC Linux Driver [Analog Devices Wiki] , I success read AD7606 data,but I doubt that the max sample rate is about 6K. /*----------------ad7606-----------------------------------*/ #define SABRESD_GPIO_AD7606_Reset IMX_GPIO_NR(3, 16) //Output #define SABRESD_GPIO_AD7606_Convert IMX_GPIO_NR(1, 17) // Output //#define SABRESD_GPIO_AD7606_Range_PIN IMX_GPIO_NR(4,15) //0utput #define SABRESD_GPIO_AD7606_Range_PIN IMX_GPIO_NR(6,3) //0utput #define SABRESD_GPIO_AD7606_Busy_PIN IMX_GPIO_NR(7, 13) //input GPIO7_13 static struct ad7606_platform_data ad7606_pdata = { .default_os = 0, .default_range = 10000, .gpio_convst =SABRESD_GPIO_AD7606_Convert, .gpio_reset = SABRESD_GPIO_AD7606_Reset, .gpio_range =SABRESD_GPIO_AD7606_Range_PIN, .gpio_frstdata=-1, .gpio_stby=-1, }; convst signal is 12.5k PWM signal, // ad CONVST static struct platform_pwm_backlight_data mx6_sabresd_AD7606_pwm_backlight_data = { .pwm_id =2, .max_brightness = 248, .dft_brightness = 220, .pwm_period_ns = 8000, }; |
这个是参考驱动代码,具体的速度还要取决于用户的CPU型号和配置。采样频率,可以用示波器测量CONVSTA/B引脚,测量CONVST信号的频率。
2282个成员聚集在这个小组
加入小组1023 浏览 2 评论
1409 浏览 2 评论
1953 浏览 1 评论
4283 浏览 2 评论
9079 浏览 1 评论
1594浏览 3评论
1709浏览 2评论
1024浏览 2评论
1695浏览 2评论
1410浏览 2评论
GMT+8, 2025-1-3 06:14 , Processed in 0.530948 second(s), Total 43, Slave 38 queries .
