可以但不合适。“The AD8015 is a wide bandwidth, single supply transimpedance amplifier optimized for use in a fiber optic receiver circuit. It is a complete, single chip solution for converting photodiode current into a differential voltage output. The 240 MHz bandwidth enables AD8015 application in FDDI receivers and SONET/SDH receivers with data rates up to 155 Mbps.”可见,AD8015并不适合对DC输入电流信号进行IV转换,它的直流误差是很大的。
建议用高精度的运放做IV转换,比如AD8605. |
2290个成员聚集在这个小组
加入小组1050 浏览 2 评论
1430 浏览 2 评论
1970 浏览 1 评论
4295 浏览 2 评论
9092 浏览 1 评论
1651浏览 3评论
1716浏览 2评论
1050浏览 2评论
1713浏览 2评论
1430浏览 2评论
GMT+8, 2025-1-14 05:18 , Processed in 0.833969 second(s), Total 75, Slave 59 queries .
