因为code跳动的比较大,所以我用校准功能,看能否解决问题,在使用校准问题中遇到一些问题,请大家帮忙解答!
1 校准有内部校准和系统校准两种,那么应该在什么情况下使用内部校准什么情况下使用系统校准? 2 PDF文档的描述中中只有失调寄存器和满量程寄存器两个,上面说的两种校准模式是共用这两个寄存器吗?如果是这样的话,当我进行内部校准之后再进行系统校准,那么内部校准的的数据不是别覆盖了吗? 3 Data = [(0.75 × VIN × Gain/VREF) × (223) – (Offset_Reg – 0x800000)] ×Full_Scale_Reg/0x400000 × 2这个公式里面的Offset_Reg和Full_Scale_Reg是内部校准系数还说系统校准系数? 4 我进行内部校准时,为什么校准过后,失调寄存器一直是0xffffff,满量程寄存器一直都是0x553a50(好像是出厂值) 贴出AD7190的代码 void Init_ad7190() { ClrCs; buf[0] = 0xff; WriteToAD7190(1,buf); WriteToAD7190(1,buf); WriteToAD7190(1,buf); WriteToAD7190(1,buf); WriteToAD7190(1,buf); delay(1000); //¸´Î»AD7190 buf[0] = 0x10; WriteToAD7190(1,buf); buf[2] = 0x00; buf[1] = 0x02; buf[0] = 0x58; WriteToAD7190(3,buf); buf[0] = 0x08; //д0x08µ½Í¨ÐżĴæÆ÷ ÅäÖá®Ä£Ê½¼Ä´æÆ÷¡¯ WriteToAD7190(1,buf); buf[2] = 0x80; buf[1] = 0x00; buf[0] = 0x60; WriteToAD7190(3,buf); delay(100); while((GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2))==1);//µÈ´ýÄÚ²¿ÁãµçƽУ׼Íê³É buf[0] = 0x08; //д0x08µ½Í¨ÐżĴæÆ÷ ÅäÖá®Ä£Ê½¼Ä´æÆ÷¡¯ WriteToAD7190(1,buf); buf[2] = 0xA0; //ÄÚ²¿ÂúÁ¿³ÌУ׼£¬×´Ì¬¼Ä´æÆ÷²»·¢ËÍ£¬Íⲿ4.9152M¾§Õñ buf[1] = 0x00; //sinc4Â˲¨Æ÷£¬½ûÖ¹ÆæÅ¼Ð£×¼£¬REJ60=1£¬¸üºÃµÄ50HzÒÖÖÆ£¬Êä³öËÙÂÊ=50Hz buf[0] = 0x60; //ÄÚ²¿ÂúÁ¿³ÌУ׼Ôڽϵ͵ÄËÙÂÊÏ¿ÉÒÔ»ñµÃ½Ï¸ßµÄ¾«¶È WriteToAD7190(3,buf); delay(100); while((GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2))==1); //µÈ´ýÄÚ²¿ÂúÁ¿³ÌУ׼Íê³É buf[0] = 0x74; //д0x74µ½Í¨ÐżĴæÆ÷ ¶ÁÈ¡¡®Ê§µ÷¼Ä´æÆ÷¡¯0111 0100 WriteToAD7190(1,buf); while((GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2))==0); //µÈ´ýÄÚ²¿ÁãµçƽУ׼Íê³É { ReadFromAD7190(4,buf); //¶ÁÊý¾Ý¼Ä´æÆ÷ InterZeroAdjustData=(u32)buf[3]<<16; InterZeroAdjustData|=(u16)buf[2]<<8; InterZeroAdjustData|=buf[1]; } buf[0] = 0x7C; //д0x7cµ½Í¨ÐżĴæÆ÷ ¶ÁÈ¡¡®ÂúÁ¿³Ì¼Ä´æÆ÷¡¯0111 1100 WriteToAD7190(1,buf); while((GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2))==0); //µÈ´ýÄÚ²¿ÁãµçƽУ׼Íê³É { ReadFromAD7190(4,buf); //¶ÁÊý¾Ý¼Ä´æÆ÷ InterFullAdjustData=(u32)buf[3]<<16; InterFullAdjustData|=(u16)buf[2]<<8; InterFullAdjustData|=buf[1]; } buf[0] = 0x08; //д0x08µ½Í¨ÐżĴæÆ÷ ÅäÖá®Ä£Ê½¼Ä´æÆ÷¡¯ WriteToAD7190(1,buf); buf[2] = 0x00; //Á¬Ðø×ª»»Ä£Ê½£¬×´Ì¬¼Ä´æÆ÷²»·¢ËÍ£¬Íⲿ4.9152M¾§Õñ buf[1] = 0x04; //sinc4Â˲¨Æ÷£¬½ûÖ¹ÆæÅ¼Ð£×¼£¬REJ60=1£¬¸üºÃµÄ50HzÒÖÖÆ£¬Êä³öËÙÂÊ=90Hz buf[0] = 0x3f; WriteToAD7190(3,buf); buf[0] = 0x4c; //д0x4cµ½Í¨ÐżĴæÆ÷ ¶Á¡®Ä£Ê½¼Ä´æÆ÷¡¯0100 1100 WriteToAD7190(1,buf); while((GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2))==0); { ReadFromAD7190(4,buf); //¶ÁÊý¾Ý¼Ä´æÆ÷ SampleSpeed=(u32)buf[3]<<16; SampleSpeed|=(u16)buf[2]<<8; SampleSpeed|=buf[1]; } SampleSpeed&=0x003f; //¶Á³ö²ÉÑùËÙ¶È } PS:通信没有问题 |
3个回答
问题依然没有解决,希望大神帮忙
可以参考一下如下的常见问题解答,其中有相关校准问题的解答
http://www.analog.com/cn/education/education-library/faqs/adc-faq-1.html |
误差多少?末了几位在跳?
输入接的电压源用的信号源?型号是? 用的SINC4/3滤波器?ODR设了多大?示波器测过输入波形?里头市电50Hz/60Hz噪声大的? PGA增益设了多大? 什么应用?ADC参考源用的什么型号? 校准用了哪种? 我的经验是做“内部满量程”校准效果最好,一般应用执行这一个即可。 最烦客户一言不和就上没有任何注释的代码。。。 能弱弱地坦诚告知:我们大公司出来的做硬件的,因分工太细,这些年来的嵌入式软件(IAR/Keil/Cortex Mx...),都是业余在鼓捣学习的。。。 |
2280个成员聚集在这个小组
加入小组994 浏览 2 评论
1388 浏览 2 评论
1940 浏览 1 评论
4272 浏览 2 评论
9063 浏览 1 评论
1528浏览 3评论
1695浏览 2评论
994浏览 2评论
1671浏览 2评论
1388浏览 2评论
GMT+8, 2024-12-24 07:30 , Processed in 0.653668 second(s), Total 48, Slave 43 queries .
