程序Debug时进入子函数,控制台显示访问0x44xxxxxx地址时出错。仔细一看,原来是子函数的局部变量存储在这个0x44xxxxxx地址。查了datasheet,0x40000000是hyperlink的地址空间,程序中根本没用到hyperlink。局部变量怎么会存储在这个地址呢?查了cmd,也没涉及hyperlink地址空间的声明呀。
3 个讨论
控制台显示内容如下
C66xx_0: Trouble Reading Memory Block at 0x445c3a44 on Page 0 of Length 0x1: (Error -1202 @ 0x445C3A44) Device core is hung. The debugger will attempt to force the device to a ready state to recover debug control. Your application's state will be corrupt. You should have limited access to memory and registers, but you may need to reset the device to debug further. (Emulation package 5.0.747.0) C66xx_0: 39 other operation(s) were automatically canceled as a result |
341 浏览 1 评论
539 浏览 2 评论
781 浏览 3 评论
655 浏览 1 评论
1138 浏览 1 评论
70浏览 29评论
220浏览 23评论
257浏览 20评论
205浏览 14评论
65浏览 13评论
GMT+8, 2024-12-25 15:02 , Processed in 0.866078 second(s), Total 46, Slave 40 queries .
