我已经看过AD9467的评估板在ZEDboard和KC705的引脚约束为"LVDS_25",对应FPGA的BANK VCCO供电2.5V,但是现在我的项目中FPGA BANK 的VCCO供电是1.8V,我对其做引脚约束为"LDVS"可行吗?
I am no FPGA expert, but i believe that LVDS is an ANSI standard. The standard depends on the differential swing of signals around a common mode voltage of ~1.2V. See datasheet excerpt below:
So if your FPGA supports this mode, then the AD9467 should be able to send data to your FPGA. 答案来源:The output of the AD9467 is LVDS level standard... | EngineerZone |
2242个成员聚集在这个小组
加入小组ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1776 浏览 1 评论
4155 浏览 2 评论
8869 浏览 1 评论
3073 浏览 1 评论
7059 浏览 2 评论
1224浏览 3评论
1534浏览 2评论
1468浏览 2评论
1236浏览 1评论
1067浏览 1评论
GMT+8, 2024-9-20 15:03 , Processed in 0.398870 second(s), Total 39, Slave 34 queries .
