3 个讨论
1,这个可以参考IPC_Users_Guide中的说明:
IPC is designed for use on processors running SYS/BIOS applications. This is typically a DSP, but may be an ARM device in some cases. Previous versions of SYS/BIOS were called DSP/BIOS. The new name reflects that this operating system can also be use on processors other than DSPs. |
336 浏览 1 评论
529 浏览 2 评论
774 浏览 3 评论
651 浏览 1 评论
1130 浏览 1 评论
60浏览 29评论
154浏览 23评论
252浏览 20评论
202浏览 14评论
59浏览 13评论
GMT+8, 2024-12-23 16:13 , Processed in 1.081501 second(s), Total 73, Slave 58 queries .
