我想在cmd文件里面加入对DDR2空间的声明,然后实现在DDR2中定义数组什么的,我的配置如下:
-c -heap 0x1000 -stack 0x3000 /* Memory Map 1 - the default */ MEMORY [ L1D: o = 00f00000h l = 00008000h L1P: o = 00e00000h l = 00008000h L2: o = 00800000h l = 00200000h DDR2: o = E0000000h l = 10000000h //DDR2's memory space is 256MB ] SECtiONS [ .csl_vect > L2 .text > L2 .stack > L2 .bss > L2 .cinit > L2 .cio > L2 .const > L2 .data > L2 .switch > L2 .sysmem > L2 .far > L2 .testMem > L2 ISRAM > L2 .ddr2 > DDR2 ] 可是对它进行编译总会出现以下错误: Multiple markers at this line - #10080-D length not specified for memory range DDR2 - #10343-D Expecting expression starting with integer, unary operator, or '(' instead of "E0000000h". - #10264 E0000000h memory range overlaps existing memory range DDR2 - #10079-D origin not specified for memory range E0000000h - #10264 E0000000h memory range overlaps existing memory range L1P - #10264 E0000000h memory range overlaps existing memory range L2 - #10264 E0000000h memory range overlaps existing memory range L1D 这是为什么 啊?我试过把地址中的“E"改成A以下的数,他就不会报错,但这个不是DDR2的地址啊。请TI员工帮助以下。 |
1 个讨论
827 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
467 浏览 1 评论
662 浏览 2 评论
264浏览 29评论
1225浏览 23评论
356浏览 20评论
334浏览 14评论
200浏览 13评论
GMT+8, 2025-3-6 02:32 , Processed in 0.829003 second(s), Total 40, Slave 35 queries .
