TMS320C6713BZDP300 芯片,工作在300MHZ时需要1.4V内核电压(CVDD),现在想让他替代TMS320C6713BZDP225,只需要工作在 225MHZ频率,那么内核电压(CVDD)是否可以用1.2V?
1 个讨论
还是用1.4v比较保险,请看下面的回复。
I just heard back from manufacturing. They indicate that 1.4V 300MHz devices are only tested to datasheet speeds at 1.4V -- there is no 100% guarantee that the -300 devices will operate at 225MHz at 1.2V. Personally, I think it should be fine using -300 devices for 1.2V/225MHz, but the customer needs to understand that they are using the drop-in replacement at their own risk. |
348 浏览 1 评论
542 浏览 2 评论
786 浏览 3 评论
658 浏览 1 评论
1140 浏览 1 评论
75浏览 29评论
249浏览 23评论
261浏览 20评论
209浏览 14评论
67浏览 13评论
GMT+8, 2024-12-26 12:26 , Processed in 1.036458 second(s), Total 45, Slave 38 queries .
