1)tms320c6713b芯片手册48页中有一段备注:
‡ IPD = Internal pulldown, IPU = Internal pullup. [To oppose the supply rail on these IPD/IPU signal pins, use external pullup or pulldown resistors no greater than 4.4 kΩ and 2.0 kΩ, respectively.] 请问To oppose the supply rail on these IPD/IPU signal pins具体什么意思?是防止电源干扰的意思吗? 2)‡ IPD = Internal pulldown, IPU = Internal pullup. [To oppose the supply rail on these IPD/IPU signal pins, use external pullup or pulldown resistors no greater than 4.4 kΩ and 2.0 kΩ, respectively.] § To ensure a proper logic level during reset when these pins are both routed out and 3−stated or not driven, it is recommended to include an external 10 kΩ pullup/pulldown resistor to sustain the IPU/IPD, respectively. 上面两段话中我理解意思是一个要求上下拉电阻应不大于4.4 kΩ和2.0 kΩ,另一段要求上下拉电阻应为10 kΩ,这两段话是否相互矛盾? 请各位专家帮忙解答下,非常感谢! |
5 个讨论
323 浏览 1 评论
513 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
386 浏览 1 评论
943 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2114 浏览 0 评论
31浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
892浏览 2评论
137浏览 2评论
172浏览 2评论
150浏览 2评论
GMT+8, 2024-9-21 08:31 , Processed in 0.958382 second(s), Total 55, Slave 48 queries .
