Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 5.1.232.0)
8 个讨论
换块板子试试,看是仿真器的问题还是板子的问题。 ***子可以参考: http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/100/t/60578 http://processors.wiki.ti.com/index.php/Main_Page Think Over Before Asking. http://www.catb.org/~esr/faqs/smart-questions.html#goal |
lifei639156 发表于 2018-8-1 08:57 解决了。 1.第一次出现“”Connect to PRSC failed“”的错误。发现DSP的CLKIN1没有输入,用FPGA 加载时钟。 2.出现 “”The JTAG IR and DR scan-paths cannot circula“ ,时钟改为硬件输入,不用FPGA. 3.出现“Device core was hung. The debugger has forced the device to a ready state and recovered debug control, but your application's state is now corrupt. You should have limited access to memory and registers, but you may need to reset the device to debug further. ”硬件设置为NOBOOT模式,connect target 之前按一次复位。 记学习DSP的血泪史。。。。。感谢同事 |
581 浏览 1 评论
419 浏览 1 评论
613 浏览 2 评论
900 浏览 3 评论
705 浏览 1 评论
181浏览 29评论
1144浏览 23评论
316浏览 20评论
277浏览 14评论
128浏览 13评论
GMT+8, 2025-2-1 02:07 , Processed in 0.864584 second(s), Total 57, Slave 51 queries .
