为了用SPI向AD2S1210寄存器写入数据,我将官网例程改成如下:
void WriteToAD2S1210(unsigned char address, unsigned char data) { unsigned char buf; //write control register address buf = address; SET_WR(); delay(1); CLR_WR(); delay(1); SpiaRegs.SPITXBUF = buf<<8; SET_WR(); //利用WR输入的上升沿予以锁存 delay(1); //write control register address //write control register data buf = data; SET_WR(); delay(1); CLR_WR(); delay(1); SpiaRegs.SPITXBUF = buf<<8; SET_WR(); //利用WR输入的上升沿予以锁存 delay(1); //write control register data } 其中SPI配置为 void spi_init() { SpiaRegs.SPICCR.all =0x0007; // Reset on, SPI上升沿移出数据, 8-bit char bits SpiaRegs.SPICTL.all =0x0006; // Enable master mode, normal phase, // enable talk, and SPI int disabled. SpiaRegs.SPIBRR =0x0004; SpiaRegs.SPICCR.all =0x0087; // Relinquish SPI from Reset SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don't disturb xmission } 想要改变激励频率 但是一直无法正确写入。 |
5个回答
参考数据手册fig32-34图,需要在配置模式下进行寄存器的读写
您好,和ad2s1210的spi读写正常了吗?
我也遇到了同样的问题,顺便请教一下,手册上我看到有可用于仿真256线的编码器,这个应该如何配置?
2281个成员聚集在这个小组
加入小组996 浏览 2 评论
1389 浏览 2 评论
1940 浏览 1 评论
4272 浏览 2 评论
9063 浏览 1 评论
1535浏览 3评论
1695浏览 2评论
996浏览 2评论
1674浏览 2评论
1389浏览 2评论
GMT+8, 2024-12-25 04:35 , Processed in 0.666776 second(s), Total 58, Slave 53 queries .
