扫一扫,分享给好友
The loop filter's BW is so strange on my HMC838 board, The BW gets so large at lower frequency(1.62GHz) and get smaller at high frequency(1.67Ghz). and also the phase noise get worse at low frequency, and actually it is not good enough at high frequency. the settings of the design are: Fref:19.2MHz, PFD:19.2MHz, Fout:16.GHz~1.7GHz, BW:50KHz. there are two plots were attached. Any suggestions? Thanks!
I think you asked the same question in Chinese. The loop bandwidth will not vary a lot over different freq since the VCO inside the part is really narrow band. We suggest you double check your loop filter or use the loop in the datasheet with 50MHz Ref.
2282个成员聚集在这个小组
加入小组1023 浏览 2 评论
1409 浏览 2 评论
1953 浏览 1 评论
4283 浏览 2 评论
9079 浏览 1 评论
1594浏览 3评论
1709浏览 2评论
1024浏览 2评论
1695浏览 2评论
1410浏览 2评论
GMT+8, 2025-1-3 06:29 , Processed in 0.657064 second(s), Total 45, Slave 40 queries .
